Advice on a vertically challenged 88mm gun crew member.
  • yak face
    • Jun 2009
    • 13840
    • Tony
    #16
    Looks fine jim he’ll be virtually the same proportionally as the driver now , although he needs to change his butcher , hes got very skinny legs !!:smiling5:
    • Bobby Conkers
      • Jan 2020
      • 529
      #17
      Shortarse Pistorius?
        Great solution Jim. He looks fine.
        • prichrd1
          • 691
          • Conwy
          #19
          Jim,
          Hope you remembered to put the prosthetic's on the correct legs!!
          :smiling2: :smiling2: :smiling2: :smiling2:
          Paul.
          :smiling2:
          • scottie3158
            • 14201
            • Holbeach
            #20
            Great fix.
            • Allen Dewire
              • 4741
              • Allen
              • Bamberg
              #21
              Looks good Jim,
              If I may ask, what is the red between his legs and the boot tops? Is that a CA type or is he really a Terminator??? And did I hear him mumble "I'll Be (in the) Back"???...
              All kidding aside, this is a really nice build and the figures will only make it better. The figure mods are definitely worth it Sir!!!
              Bleib Gesund
              Allen
              • JR
                • May 2015
                • 18273
                #22
                Jim .
                I was going to say put a box under his feet, but seeing the result with the extension it's looks fine. Neat idea .:thumb2:
                • tr1ckey66
                  • Mar 2009
                  • 3592
                  #23
                  I need to look into this surgery. I could be a six footer!
                  Good fix
                  P
                    Though that was a joke, there is actually a similar real-world surgical technique to make people taller: the bones in the leg are broken on purpose, then held a bit further apart than they were so that when the break heals, they’ll be longer.
                    • Bobby Conkers
                      • Jan 2020
                      • 529
                      #25
                      This can also be done with "other" appendages, although how short it would need to be to let someone chop it in half I can't imagine.
                      • stillp
                        • 8093
                        • Pete
                        • Rugby
                        #26
                        I have a problem with my wrists, caused by one of the bones in the forearm having grown a bit longer than the other, which means it rubs against something it shouldn't, causing inflammation. The 'cure' offered is to break the forearm and snap a bit off one of the broken parts. I think I'll keep taking the painkillers and anti-inflammatory pills.
