Masking up aircraft. your best techniques
  • Defiant911
    • Feb 2020
    • 640
    As I’m fairly new to this I have masked up a few planes but I do find the masking quite a chore and sometimes I end up with over spray where I don’t want it. I’m sure there is a more organised approach to how I’ve been doing it so I’d be interested to hear how others tackle masking aircraft?
    Carl
    • 15677
    I use thin flexible tape to demarcate the edges and then fill in with ordinary tape.
    • rtfoe
      • 9074
      I normally approach the smaller areas first which I mask then paint the main color at the end. This minimizes the amount of masking tape needed and covering less of the large areas thus also minimizing overspray. That's the reason I do pre-shading. It's easier to control and cover mistakes with the final coat than the opposite for me that is.
        Carl,
        I'm afraid there isn't any easy way of masking, it's just a matter of systematically working through it. I'm always aware that overspray will find the slightest chink! I sometimes use clingfilm to cover large areas that I don't want to get any paint on, using tape to seal the edges.
        Before masking make sure that the surface is clean & dry - if over another painted surface, I allow at least 24 hours before masking. Remove the masking tape when the new paint is touch dry, if you leave it a long time, then you can lift the paint. Make sure that the masking tape is burnished down at the edges - I use a paintbrush handle. You can try to seal the edges with varnish, to prevent bleed through/under, but that can cause more trouble.
        This how not to do it!!! Poor surface preparation - poor choice of primer - insufficient time to let the basecoat dry before masking - result, a lot of bad language!!
        Just about recoverable - removed as much loose paint as possible, feathered all the edges, reprimed etc etc - I lost heart, and it still ain't finished!!
        • Defiant911
          • Feb 2020
          • 640
          Do you not find
          Carl,
          [ATTACH=CONFIG]n1125540[/ATTACH]
          wow, that looks a lot of work. I’ve experienced paint coming away after masking but usually it’s the primer rather than the main coat. I imagine sanding that back over all those bumps will be very time consuming...the fun of modeling..
          • Defiant911
            • Feb 2020
            • 640
            Do you get any overlap lines by masking in sections?
            • rtfoe
              • 9074
              Carl, I normally don't get overlap lines as I spray very thin coats of paint...thinner than the tape itself. One of the best ways to get the no overlap effect is to use paper masking and spray away from the edge or use Blu-Tac.
              If you're painting with a paint brush I would suggest not using any masking. With an airbrush you cannot run away from masking if you want an abrubt line or sharp feathered edge. Have you tried using a paper doily placing it on a surface and spraying over it? Spray at different angles and see the results and you will start to understand the effects of masking with paper. With tape, always use a new cut strip to spray on as it will not carry any dirt or unwanted dust that the tape has picked up when left on the table. I always believe in experimenting and practise on an unwanted old kit first before attempting on a new kit.
              • BigGreg
                • 2182
                i personally do like this..
                i previously washed the model with isopropyl alcohol... when it's dry....
                1. Primer a light coat with one of the camo colors ( the darkest one)
                2. a thin coat of ultra matt varnish from AK interactive or MIG
                3. put the flexible tape from tamiya (white one 2mm) and cover the part with paper tape from tamiya (yellow on 1cm)
                4. repeat 2 (the ultramatt is to be sure that the tape will not take off the paint)
                5. another camo repeat number 3
                6. apply the decals
                7. repeat number 2
                8. wash-weathering and pigments..
                PLEASE be sure to apply THIN layers of paint..
                hope this helps
                • PaulTRose
                  • Jun 2013
                  • 6459
                  • Tattooine
                  must admit that masking is one reason i dont do many aircraft....its something i really hate, especially canopies and the demarcation line on leading edges!
                  i tend to use very thin good quality masking tape for straight lines....blutac for curves.....coupled with patience counterbalanced by a lot of swearing
                  Per Ardua
                  • BarryW
                    • Jul 2011
                    • 6010
                    I dont mask wing leading edges at all, there is no need. Just spray straight down onto the wing and from above forward and the curve takes care of all the masking.
                    Cockpits arer fairly easy, with some models you can just mask the canopy and fix that in place. You can fix it temporarily as well if you intend to display it open. Otherwise I just pop some screwed up tissue into the pit and use masking tape around it. Little pieces of tape will do, some perhaps cut to a rough shape. The same method works for all sorts of holes and gaps.
                    Demarkation between upper an lower fuselage can be done using blue tac snakes with masking tape. Flowing camo shapes by using Clever Putty.
                    • adt70hk
                      • Sep 2019
                      • 10404
                      Never thought of using cling film! A great idea!
                      ATB
                      • stona
                        • Jul 2008
                        • 9889
                        1. I spray the underside colour, which is almost invariably lighter than the upper surfaces, not worrying about the demarcation, except to make sure I cover it.
                        2. I mask the demarcation between upper and lower colours and then mask the underside of the model. I use a combination of tape and kitchen (aluminium) foil. The foil is a lot cheaper than Tamiya tape
                        3. Spray the lighter (or lightest) camouflage colour on the upper surface. I post-shade so I do anything in a version of this colour at this stage.
                        4. Mask the lighter colour. A splinter type pattern can simply be done with tape. Curvy patterns can be done with Blutack.
                        Once you are happy with the demarcations, fill in the area to be masked with tape and spray the next colour.
                        Remove masking and....voila!
                        I work at 1/32, so I often spray the various national and other markings.
                        And then do all the usual gloss coat(s) and decaling thing.
                        Small piccies, because they are just illustrations and will load a lot faster!
                        Canopies are a thing unto themselves. I like to have mine attached to the model, permanently or temporarily, when I paint because I don't want it to look 'stuck on' later. I have tried all sorts of methods, but almost always revert to the masking tape and new, sharp, No 11 scalpel blade. It is quite often a fiddle and on very complicated framing I am not averse to splashing out on some pre-cut masks. I certainly did that when I made a 1/48 Lancaster and it was worth every penny!
                        • PaulTRose
                          • Jun 2013
                          • 6459
                          • Tattooine
                          you work in 1/32 where i guess its easier than the 1/72 that i work in, .....lots bigger!
                          Per Ardua
                          • BarryW
                            • Jul 2011
                            • 6010
                            I would have thought small scale would be easier. The last 1/72 I built was when they released a Tiffy, a year or so before the 1/24 came out!
                            • PaulTRose
                              • Jun 2013
                              • 6459
                              • Tattooine
                              you try masking a canopy for a 1/72 Me 110 or Ju 87 :tears-of-joy::tears-of-joy::tears-of-joy:
                              Per Ardua
