Tool for accurate cutting of plastic strip??
Thanks chaps, will have a good old think. I am using evergreen which seems fine
I have bought a cheap set square so practice is neededComment
WELL guys my take on evergreen its too exspensive as i bought a sheet of chequer plate a little while ago an it was £8.99 for one sheet an fair enough i know its got the anti slip pattern on it but i would not think it cost that much to make it just as well thats all i needed an just my opinion
chrisComment
If you just need plastic card, then generic, nameless is just as good as brands like Evergreen and whathaveyou, but generally far cheaper. I just did a quick check, and saw prices like €6 for two sheets of 300 × 150 × 0.75 mm; I then went to my hobby room, where I have a nameless plate of that same thickness, 300 × 500 mm large, that cost me €1.99 (says the sticker on it).
Evergreen etc. are good for strip, profiles, etc., which I can’t seem to find from nameless makes, and for specialty cards embossed with profiles, ridges, etc. — and even there you can find generic ones, if you’re lucky/look hard enough.Comment
Best with out doubt & most accurate with a clean edge.
A thick edge steel rule. A Stanley knife with a new blade.
First cut just a light draw to provide a tram line. Than a full cut. Depending on thickness.
Do not dig as my carpenter father instructed me. Let the tool do the work my son.
It is quick easy cheap.& it works perfectly.
LaurieComment
Thanks again all
Sound advice, :thumb2:
Have bought evergreen angle, ideal for mounting spare wheel brackets!!Comment
It certainly is Laurie.
I mentioned it yesterday, but I forgot to mention your mention of the pressure on the blade/saw teeth, which is spot on.
I still have the scars on my thighs where I was clouted by a hand saw, expertly wielded by the bloke who was trying to teach me to be a joiner in '63
Thwack! "Look son, let the bl**dy saw do the work, that's what the bl**dy teeth are for!"
As you rightly point out, gently does it with a blade. Too much pressure and it will wobble off course.
RonComment
Thwack! "Let the bl**dy saw do the work, that's what the bl**dy teeth are for!"
Ron
LaurieComment
Ron
Next Chisels & plane blade. Honed with perfection in mind & they were sharp. Then he would strop the chisels & plane blades on his palm to remove any burrs.
Skirting no mitres he scribed one skirting over the other absolute fit. Could not get a razor blade in the joint on his architrave mitres. Joy to watch him work. The old fellow went a time ago & I miss the old blighter. A good dad.
LaurieComment
Always lots of laughter. 82 but I have my eyes on Capt. Tom 100. When I get there I will have to reassess the situation :smiling:
LaurieComment
