Another PE question
  • BattleshipBob
    • 6785
    • Bob
    • Cardiff
    Another PE question
    Evening all
    About to fight with more PE and i need advice. Grown my nails longer so i can bite them!!!
    On the smaller or fiddly bits is it best to put the CA/glue on the PE??
    Ta in advance Bob
  • Si Benson
    • 3572
    Hi Bob,
    I would imagine everyone has there own valid way.
    I will quite often hold the smaller bits in tweezers and carefully dip into my blob of CA then pop into location.
    • prichrd1
      • 691
      • Conwy
      Bob,
      Personal preference really and how steady a hand you have - but that's the way I work with small fiddly bits!!
      Alternatively there's always the tried & trusted MIG welder or a 4" nail!! :flushed:
      I'll grab me coat now!!
      Paul.
      :smiling:
      • BattleshipBob
        • 6785
        • Bob
        • Cardiff
        Originally posted by Si Benson
        Hi Bob,
        Hi Si, sounds like a plan!!
        Originally posted by prichrd1
        Bob,
        Paul.
        :smiling:
        My welding is terrible but can hit in a nail with the best of them Lol
        • scottie3158
          • 14197
          • Holbeach
          Bob,
          As Paul said it is a matter of preference, for me it depends on the part and where it is going whether I dip the part in the glue of place a drop where the part will go. You will find what works for you best.
          • BattleshipBob
            • 6785
            • Bob
            • Cardiff
            Thanks Paul
            Appreciated
              • 15645
              Hi Bob
              Most of the time I place the PE using Gator acrylic hobby glue. It allows time to get the PE into position. I then wick thin CA glue into the join. Often, for PE with a larger attachment point, the Gator glue is fine on it's own. Any Gator glue that squeezes out it easily cleaned up with a damp brush before it dries. If you do cock things up the part is easily removed, cleaned up and you're ready for another go.
              • BattleshipBob
                • 6785
                • Bob
                • Cardiff
                Originally posted by Jim R
                Hi Bob
                Excellent, many thanks Jim!
                • Steve Jones
                  • 6615
                  I did my first bit of PE soldering this weekend. It was great fun. Give it a go mate
                  • BattleshipBob
                    • 6785
                    • Bob
                    • Cardiff
                    [ATTACH alt="fgreg.JPG"]405785[/ATTACH][ATTACH alt="IMG_1201.JPG"]405786[/ATTACH][ATTACH alt="IMG_1203.JPG"]405787[/ATTACH]
                    Good god Steve, give me time to get smoke alarm lol
                    • JR
                      • May 2015
                      • 18273
                      Bob I always have fun using pe and ca. Normally a small amount on a piece of card then attempt to pick up the part with tweezers or wax pencil , or the blade of a scalpel if its resin.
                      At this point I either drop the part , or fire if into the third dimension( only to be found weeks later leaving me wondering what it was )
                      Doing what Si and Paul do is good, but don't get any on the tweezers or you'll not get the part off them !
                      I like Jim's method ,bought the Gator glue and always forget to use it. Think the guy has just stopped selling it !
                      Oh , I have a spray which I use to speed up the process after the part is on. I use this set others are available.
                      Evo-Stik Mitre Adhesive 50g + 200ml
                      By Evo-Stik Product code: 71377 Pack size: Each
                      • SteveH
                        • 1287
                        Morning Bob
                        Some great ideas already on the thread.
                        Steve J is spot on with soldering being fun, I tried the Adam Wilder DVD on PE soldering a few years ago, I think you can get most of it on You Tube these days too?
                        I really enjoyed it and recreated the T34/85 with Thoma shields too.
                        It is a bit of a "Black" art, but when you hit the sweet spot, it really is a blast.
                        I have a retirement project to build a 1/35 Pz I A in Brass, and have a box full of every PE set possible to achieve it.
                        Have fun either way, and always plan before melting your PE LOL
                        Regards
                        Steve H
                        [ATTACH]405797[/ATTACH]
                        • BattleshipBob
                          • 6785
                          • Bob
                          • Cardiff
                          Bob I always have fun using pe and ca. Normally a small amount on the ears then attempt to pick up the part with tweezers or wax pencil , or the blade of a scalpel if its resin.
                          [ATTACH=CONFIG]n1138125[/ATTACH]
                          [ATTACH=CONFIG]n1138126[/ATTACH]
                          Many thanks Jim, excellent advice
                          Originally posted by SteveH
                          Morning Bob
                          Regards
                          Steve H
                          [ATTACH=CONFIG]n1138127[/ATTACH]
                          Lovely job Steve, not sure if i will get detailed, having fun with just the basics lol
                          • prichrd1
                            • 691
                            • Conwy
                            Who said anything about using tweezers - more fun if you have sausage shaped fingers and a squirty bottle of CA!! :smiling: (Typing with pencil in mouth!!:flushed::flushed.
                            Paul.
                            :smiling:
                              • 15645
                              Often particularly, small and fiddly PE requires a special approach and special tools. It doesn't actual help with the PE but after a frustrating hour or two it makes you feel better. This is my go to tool kit.
