Another PE question
    After taking a deep breath - I use a cocktail stick to apply a drop of CA to the desired location, then apply the PE bit with tweezers. I use either aluminium foil, or pie cases to squirt a little CA puddle for my cocktail stick - no way could I allow the CA bottle anywhere near the model! If you do get CA on your tweezers, a lighter flame will burn it off. As always I work on the principle of ' does this part actually do anything for the model?' and 'if I can't pick it up with my tweezers, I'm not using it!'. Just because a part is on the PE fret doesn't mean you have to use it - I reckon some parts are just added as fillers, to boost an otherwise sparse fret!
    • BattleshipBob
      • 6792
      • Bob
      • Cardiff
      #17
      Hi Dave, totally agree
      The pe set for the Tamiya StuG has bits that are so fine it would drive me nuts and any improvement??
      Thanks for the valuable info!!
      Bob
      • scottie3158
        • 14199
        • Holbeach
        #18
        A very useful tool to make as a glue applicator is to take a needle place the pointy end in a suitable handle the nip off the eye of the needle to leave a fork. When the glue builds up just burn it off as Dave says but don't breath in the fumes.
        • BattleshipBob
          • 6792
          • Bob
          • Cardiff
          #19
          Thats a good one Paul, have tried using thin wire, that clogs very quickly
          I have some scrap pe so will practice!
          • JR
            • May 2015
            • 18273
            #20
            Many thanks Jim, excellent advice
            Bob, since when did I change my name to Jim, Taxi to Specsavers .:smiling3:
            • dave
              • Nov 2012
              • 1828
              • Brussels
              #21
              Here’s my version of the home made applicator.
