CA accelerators, advice?
  • BattleshipBob
    • 6792
    • Bob
    • Cardiff
    Me again, sorry!
    After advice about using and types of CA accelertors
    Andrew has pointed out one type , are most sprays? I would imagine a spray would waste a fair bit?
    Would appreciate some pointers if possible
    Ta bob
  • JR
    • May 2015
    • 18273
    Yes the sprays do waste a lot I think. When you only need the smallest amount like the CA itself you get a great dollop and cover most of the model. Wonder if spraying some into a lid and using a old paintbrush / needle to drop a small amount into the area would work
    Before you rush off to buy expensive modelling types have a look on Amazon Bob,I've just run out and will try there first .
    • adt70hk
      • Sep 2019
      • 10402
      Bob
      This is what the tip looks like on my 'pen' version.
      ATB
      • JR
        • May 2015
        • 18273
        Originally posted by adt70hk
        Bob
        ATB
        [ATTACH]407045[/ATTACH]
        That look just the thing Andrew.
        • adt70hk
          • Sep 2019
          • 10402
          Thanks John. Stumbled on it by accident. Works well too. Just drag the piece across the tip and hey presto.
          • BattleshipBob
            • 6792
            • Bob
            • Cardiff
            Thanks both
            So you wipe the pe part then add ca to either the part or the kit and attach?
            Thanks bob
            • adt70hk
              • Sep 2019
              • 10402
              Thanks both
              Thanks bob
              Hi Bob
              The few times I've used it, be it DIY or modelling, is to put the CA on the thing the item is being glued to e.g. wall or model.
              I then apply the accelerator to the thing being offered up to the surface or attached to a kit e.g. stowage or PE.
              in the case of modelling as you can see the tip is far too chunky to be precise with and so it is much easier to drag the item being glued on across the tip to apply the accelerator.
              You have to be pretty careful with placement as the accelerator is surprisingly effective.
              Hope that helps.
              • JR
                • May 2015
                • 18273
                Thanks both
                Thanks bob
                Morning Andrew and Bob, I've been looking at U Tube and found this. Going to give it a go .
                See what you think.
                • Steve Jones
                  • 6615
                  I use three CA's Bob. Gorilla Glue which is slow setting allowing you to move the piece if needed to do fine adjustments. Industrial strength CA which sticks as soon as it hits the plastic. Black CA glue which shows up where the glue is so you can clean it off with debonder. The world of CA glue is an enormous one and everyone has different CA's they like and use. Over time you will find a system/particular CA that you like and does the job for you. Keep asking the questions my friend as its always a short cut to having to work it out yourself.:thumb2:
                  • adt70hk
                    • Sep 2019
                    • 10402
                    See what you think.
                    Thanks John. Another hint to squirrel away.
                    ATB
                    • BattleshipBob
                      • 6792
                      • Bob
                      • Cardiff
                      Many thanks Steve, it is a bit confusing lol
                      • BattleshipBob
                        • 6792
                        • Bob
                        • Cardiff
                        Anybody tried the Revell fix kit UV glue, sounds interesting??
                        Bob
                        • stona
                          • Jul 2008
                          • 9889
                          I have a home made accelerator in an old Tamiya glue pot (50ml maybe?)
                          It's a mix of IPA and sodium bicarbonate, like yer man's, but probably a bit more bicarb, I didn't weigh anything, just used a spatula.
                          I've not noticed any issue with residue, but I only use it for things where you need a really quick 'grab', like attaching antenna wires.
                          It definitely works and the cost is almost nothing.
                          • wasdale32
                            • 1115
                            • Mark
                            Interesting if IPA/Bicarb works as that would keep quite well in a recycled Revell Contacta container with the needle applicator - or even in a syringe - the issue I have with the spray versions (I use Expo at the moment) is the overspray. But the spray does evaporate very quickly.
                            • JR
                              • May 2015
                              • 18273
                              Bob
                              Bob think Neil Merryweather has used something like that, perhaps a pm to him might help.
