CA accelerators, advice?
  • BattleshipBob
    • 6792
    • Bob
    • Cardiff
    #16
    Bob think Neil Merryweather has used something like that, perhaps a pm to him might help.
    Many thanks John
      Another cheap and simple trick to getting superglue to set more quickly is to breathe on it: it sets because of a chemical reaction with water, so if you supply it with additional moisture from your breath, it will set more quickly.
      • stona
        • Jul 2008
        • 9889
        #18
        Yes. That certainly works too but doesn't give that quick 'grab' you might need attaching an antenna wire or similar.
        • BattleshipBob
          • 6792
          • Bob
          • Cardiff
          #19
          Thanks again all
          Much appreciated, hair dryer too powerful?? Not mine of course lol
          Bob
          • Neil Merryweather
            • Dec 2018
            • 5184
            • London
            #20
            I've replied to Bob about the UV glue but I thought I would just drop in my two penn'orth on activator.
            At work we rarely use the atomiser as it can affect the paint and 'bloom' the clear acrylic.
            We decant it into a dropper bottle like this- much more controllable and economical.
            hope this helps
            N
            • BattleshipBob
              • 6792
              • Bob
              • Cardiff
              #21
              I
              hope this helps
              N
              Thanks Neil, i have some of those!
                True, it works well if the part already sticks in position (or you can press it there) but the glue isn’t setting as fast as you want. If the part doesn’t want to stay, it’s not much help
