Making masks for wiper sweep on windscreens.
  • outrunner
    • Apr 2019
    • 2420
    Any short cuts or easy way to make the above and which masking tape is best? I was playing about for a while earlier and can not seem to get it right.
    Andy.
  • PaulTRose
    • Jun 2013
    • 6464
    • Tattooine
    you need a compass cutter to get the arc right...........i just use cheapest modelling tape i can get.....needs to be wide enough
    Per Ardua
    • Del640
      • May 2020
      • 1151
      Interested in this as I'm half way through a Velociraptor and I've just ordered a Kübelwagen!!!
        • 18907
        Best tape is Tamiya in my opinion. Echo Paul ref the compass cutter. It’s far easier than trying to find the right sized jars etc. Olfa is the usual make. You could make do with just a standard compass if you are good at cutting curves though.
          Yes, Tamiya Masking Film & an Olfa cutter
          Wiper pivot point & top end of blade gives outer diameter, pivot point & inner end, inner diameter. then just careful application.............................
          • Del640
            • May 2020
            • 1151
            [ATTACH=CONFIG]n1141700[/ATTACH]
            Dave,
            I've done a quick search, but can't find the relevant Olfa cutter... Pointers?
            Del
            Edit: found plenty of the cutters, recommendations on size?
            • spanner570
              • 15402
              Del, can't you just pencil in the wiper arcs and then simply apply a light wash of whatever paint with a brush? This would also induce some very nice slight runs and streaks,
              • Del640
                • May 2020
                • 1151
                That would entail a level of expertise and competency.....I wouldn't know where to start!
                  • 18907
                  There you go Del. There are many other suppliers though.
                  • Del640
                    • May 2020
                    • 1151
                    Cheers Tim,
                    That's the one I was looking at but it doesn't mention how small it goes down to.. Only the max (6")
                      • 18907
                      Looking at the “questions and answers“section it goes down to 1 cm diameter (0.5 cm radius) circles Del.
                      • Del640
                        • May 2020
                        • 1151
                        Le
                        Ordered!
                        • outrunner
                          • Apr 2019
                          • 2420
                          What type of surface do you guys use when cutting the tape as I am not having much success with my cutter as the point keeps moving or the blade digs in to my cutting mat.
                          Andy.
                            I use a piece of cardboard - the compass cutter point will dig in nicely - If the blade digs in you're pressing too hard - use several light cuts, rather than one heavy
                            • Del640
                              • May 2020
                              • 1151
                              As Dave says, I use a cutting mat but effectively 'score' the shape initially then just go over that until clean through.
