After 1 35 chain?
  • GerryW
    • Feb 2021
    • 1757
    #16
    Not sure if it'll be small enough, but what about a bit of an old silver jewelry chain - some of those are tiny.
    I'll have a look in my O&S box and see what I've got.
    Though this one isn't suitable (box link & gold) gives an idea of how small they go - the rifle is a 1/35 Mauser
    I'll be able to have a 'proper' look in the box later to see what I've got
    • JR
      • May 2015
      • 18273
      #17
      That would certainly hang better than those pe ones Gerry .
      [ATTACH=CONFIG]n1145070[/ATTACH]
      • GerryW
        • Feb 2021
        • 1757
        #18
        Just had a quick look on eBay, can get a 1 mm 18" silver belcher chain for £3.50-ish including postage - so not even worth me sending a few links for the price of postage!
        • JR
          • May 2015
          • 18273
          #19
          No it's not, Bob will no doubt look in later and see your post Gerry. He probably in some field trying to start his beloved StuG .:nerd:
          • GerryW
            • Feb 2021
            • 1757
            #20
            Just gone into how jewelry chains are measured - seems that they're measured across the link, rather than how 'normal' chains are, which is the length of the link, so probably a '1mm' silver chain would be about a '3mm' normal chain (just guessing though)
            • BattleshipBob
              • 6803
              • Bob
              • Cardiff
              #21
              Thanks Gerry and John
              Much food for thought!
              Will have a look at some of the StuG modelling books, hopefully the builder will mention what size chain they used!!
              Tried to gently bend the flat PE chain with the kit and yes snapped
              • GerryW
                • Feb 2021
                • 1757
                #22
                Just had a look, only got 'curb' chains (no good, as the links are 'twisted' on them) - could have sworn that I'd got a 'belcher' there somewhere! Sorry, I can't give 'proper' measurements
                • BattleshipBob
                  • 6803
                  • Bob
                  • Cardiff
                  #23
                  Hi Gerry, appreciate the effort
                  Had a look through my books, can see the chain on a lot of models but only one maker mentions the chain, Tiger Model Designs, have messaged them
                  Thanks Gerry
                  • outrunner
                    • Apr 2019
                    • 2420
                    #24
                    Bob, did you try heating the PE with a lighter to anneal it and make it easier to bend?
                    Andy.
                    • BattleshipBob
                      • 6803
                      • Bob
                      • Cardiff
                      #25
                      Andy.
                      Hi Andy, no, not sure as its very fragile. Will try to see what happens?
                      Thanks bob
                      • BattleshipBob
                        • 6803
                        • Bob
                        • Cardiff
                        #26
                        Joe at Tiger models advised using PE for the smoke candles, he has chain but due to the new vat does not now send to UK. He is looking for a UK stockist, very helpful to be fair
                        • scottie3158
                          • 14221
                          • Holbeach
                          #27
                          Bob,
                          The way I make my really thin chain is to take two strands of the thinnest wire that i have and twist them together until the twist are about the size of the link you want. next with some flat pliers gently pinch the strands flat. then cut to length. secure the ends with a bit of a CA. I will try and post some pics later.
                          • Peter Gillson
                            • 2594
                            #28
                            When the shops are open again, try Primark of Accessorze, both shops sell cheap accessories and jewellery. Most have the weong style of links but I have bough some which are the rich sizd and shap, usually for onlt a couple of quid.
                            Peter
                            • BattleshipBob
                              • 6803
                              • Bob
                              • Cardiff
                              #29
                              Bob,
                              Thanks Paul, kind of you:thumb2:
                              Originally posted by Peter Gillson
                              When the sops are open again, try Primark of Accessorze, both shops sell cheap accessories and jewellery. Most have the weong style of links but I have bough some which are the rich sizd and shap, usually for onlt a couple of quid.
                              Peter
                              Thats a good idea, thanks Peter!!
