Tamiya Extra Thin Cement Question
  • JR
    • May 2015
    • 18273
    #16
    I'm going to have to lie down ! and change my name to Confused . :smiling2:
      Yes you get "stuck" in their John.
      • stillp
        • 8097
        • Pete
        • Rugby
        #18
        Dot Com?
          • 18932
          Love it LOL....
          by the way, cement holds bricks apart.....if it was a glue it would hold them together :tongue-out3:
          Getting technical, cement is a constituent part of mortar and concrete.....and it reacts chemically to do its job. It’s therefor a glue, so there:tongue-out3::tongue-out3::tongue-out3:
          • Bortig the Viking
            • Mar 2019
            • 780
            #20
            Love it LOL....
            Do you want a job as a builder, got a little wall needs building.:tongue-out3:
            • stillp
              • 8097
              • Pete
              • Rugby
              #21
              Love it LOL....
              It doesn't react chemically with the bricks though does it? :tongue-out:
                • 18932
                You couldn’t afford me Mark, but if you did, you’d really regret it LOL....
                  • 18932
                  I never said it did.....it reacts chemically with the constituents of mortar, which makes mortar work.......and mortar is the glue.....still with me? I’m not :tongue-out3: :tongue-out3: :tongue-out3:
                  • Bortig the Viking
                    • Mar 2019
                    • 780
                    #24
                    :tongue-out::tongue-out3:
                      Actually mortar for brickwork should be a holding meduim. It binds the bricks together.
                      Bricks move with temperature & also water absorbtion so need a holding matter which has a flexibiltiy. Using the incorrect mortar, which may be termed as glue, will result in many cases the brickwork failing with cracking some times considerable & in some cases dangerous. Mortar provides a bed on which the bricks rest & are kept in position. The bricks are self supporting in a restrained position (except when they crack)..
