Cheers mate. Hopefully have it finished in a couple of weeks
What's on the Bench? 2021
Hi Paul
i mainly use a Scalpel fitted with a number 15A blade, and sometimes some 400 grit wet and dry. The blade is a small curved one that can be used to scrape or cut. I prefer curved blades for scraping because you don’t get surface scratches. Takes about fifteen minutes a figure though….Comment
Hi Paul
Getting towards the end of my stalled 263 armoured car shelf Queen, so on to the next thing……
I’ve Zenitel primed some adventurers for my Frostgrave set up..
[ATTACH=CONFIG]n1162492[/ATTACH]
……and the same on some spear armed Lawn ornaments for my Oathmark armies….
[ATTACH=CONFIG]n1162493[/ATTACH]
Both of these are 28mm North Star multipart plastic figures. They are made from a mix and match set of parts, giving many variations on a basic theme. The only addition I’ve made out of the box is the arrow on the archer. He looked weird without one so I added one from suitably sized brass pin wire.
As always, any questions fire away…..
They look very nice indeed. Looking forward to seeing these done!
ATB
AndrewComment
Hi Everyone. Finally managed to get the camo scheme done. Bit of a toughie but pleased with the result. On with the weathering now.
[ATTACH=CONFIG]n1162029[/ATTACH][ATTACH=CONFIG]n1162030[/ATTACH][ATTACH=CONFIG]n1162031[/ATTACH][ATTACH=CONFIG]n1162032[/ATTACH][ATTACH=CONFIG]n1162033[/ATTACH]
Happy modelling .
That "Jigsaw" type camo has to be one of the hardest to get to look "right".... And you've certainly more than achieved that mate!
A cracking result to be sure !!
AndyComment
The black lines helped a lot tidying it up but it was fun to do, but then I am a masochist :smiling5: :smiling5::thumb2:
.... Couldn't get back to sleep when I got back!
I see what you're saying about the black lines helping.... it's still a tricky look mind to get mate
AndyComment
I'm starting to realize that, where the line goes through complex detail, it's sometimes better to lose some of that detail in order to remove the line, rather than making an awful mess trying to work around it.
It's still a mighty pain!Comment
As well as the small curved scalpel blade (I think it's actually 15, not 15A), fine emery paper and sanding sponges, I've been using the Citadel mouldline remover, which works surprisingly well for some stuff.
Absolutely right. The line jumps out far more than the loss of detail. My pet hate is designers that put the mould line right through the middle of the face along the line of the nose :angry::angry::angry::angry::angry: The Perry Sudan Brits are a classic example. Great sculpts but really stupid mould design on the heads…..I suppose the only up side is that you get proper ears…..Comment
