I’d go with a small single fold of 400 grit wet and dry. It should be stiff enough to keep its shape and so work like a very fine round file, leaving you able to remodel the wavy hair if needed…..it should work on the cloak as well…..
What's on the Bench? 2021
Hi Paul
i mainly use a Scalpel fitted with a number 15A blade, and sometimes some 400 grit wet and dry. The blade is a small curved one that can be used to scrape or cut. I prefer curved blades for scraping because you don’t get surface scratches. Takes about fifteen minutes a figure though….
The 15 is the most-used blade in my varied armoury - definitely the most versatile and I'd recommend anybody to add them if not already in possession!
SteveComment
Totally agree. I buy them by the hundred……it’s far cheaper. I use unsterile only though, I’m cutting plastic, not skin!Comment
