What's on the Bench? 2021
  • minitnkr
    Charter Rabble member
    • 7551
    • Dayton, OH USA
    #1006
    A beauty Rick, the second of the pair did not have rear suspension, axles, gas tank or spare tire rack & tires. I can cobble everything eventually, but am concentrating on the one w/all its' parts now.
    • Mini Me
      • Jun 2018
      • 10711
      #1007
      Paul, at least you have a pattern you can copy to make the second rack. Looking forward to see how it turns out. Rick H.
      • Lee Drennen
        • 7711
        #1008
        This is on my Bench tonight. I have to give that Braille Scale a break for now my hands and eyes has had enough so I’m going to my favorite Scale in Millitary 1/48. This was a old Monogram Snap Kit back in 1978. I’ve had it for a long time and wanted to make the trailer into a Millitary Cargo Trailer with stakes. The Stakes are Plastic that I robbed from a 1/50 flat bed truck. Click image for larger version
        • Mini Me
          • Jun 2018
          • 10711
          #1009
          Go for it Lee......should be interesting. Rick H.
          • Lee Drennen
            • 7711
            #1010
            Thanks Rick I’m almost halfway finished with this I’ll post updates later
            • Lee Drennen
              • 7711
              #1011
              Here’s what I’ve got done this Morning. I added some Styrene to the front and back of the Trailer. Added some PE including tie downs. Made a working Jack and added a some “D” rings made out of wire. I also made a new Front hitch and added a Tail Light. Hope to have this off the bench soon.
ID:	1164594Click image for larger version
ID:	1164595Click image for larger version
ID:	1164596Click image for larger version
ID:	1164597Click image for larger version
ID:	1164598Click image for larger version
ID:	1164599Click image for larger version
ID:	1164600Click image for larger version
ID:	1164601Click image for larger version
ID:	1164602Click image for larger version
              • Steve Jones
                • 6615
                #1012
                Lovely work Lee. Coming along real well
                • Mini Me
                  • Jun 2018
                  • 10711
                  #1013
                  All good Lee :thumb2: Rick H.
                  • Lee Drennen
                    • 7711
                    #1014
                    Steve. Thanks for the complement this was more fun than I thought.
                    Rick. Glad you approve.
                    • Lee Drennen
                      • 7711
                      #1015
                      Ok I have to paint the tail light and I just ordered some Stowage for it from Value Gear. When it gets here I’ll add it to the trailer and post it in the Completed section. Thanks for all the likes and complements.
ID:	1164608Click image for larger version
ID:	1164609Click image for larger version
ID:	1164610Click image for larger version
ID:	1164611Click image for larger version
                      • rtfoe
                        • 9100
                        #1016
                        Currently correcting part of someones commission build 1/700 USS Knox. The side quarterdeck cheeks are supposed to be flush with the hull.
                        • minitnkr
                          • 7551
                          • Dayton, OH USA
                          #1017
                          Top two are completed Heiser CCKW 352 resin, middle two are WIP unknown maker soft metal CCKW 352, bottom two are WIP ROCO Corbit/Brockway 6x6x6 short & long WB cargo trucks. Short WB versions are primarily used as prime movers for towed arty. or equipment. The top four are to complete a Cannon Co. 105mm section. The btm. two are for Engineer bridging elements.
                          C&Cs welcomed.
                          • MAK2020
                            • Sep 2021
                            • 210
                            #1018
                            Modeling and printing 5L can. Printed in 1/35 scale.
                            • Mini Me
                              • Jun 2018
                              • 10711
                              #1019
                              [ATTACH]440068[/ATTACH]
                              C&Cs welcomed.
                              Those are looking good Paul. I found a chassis for the old Roco Lacrosse Missle carrier/launcher and noticed the shorter wheel base, wonder if it's the same as your short WB 352's?....might have a go at "cobbling" one together. (edit) Actually the chassis is for the Roco 2 1/2 ton tandem axle tractor M48 that came with the van, Tank, or stake bed semi trailers. Sorry for the confusion. Rick H.
                              • rtfoe
                                • 9100
                                #1020
                                Cheeks all flushed up, masts straightened now looking for a skip and lifeboat for the empty davits. Not forgetting the SH-2 Seasprite.
