File Recommendations
  • Bortig the Viking
    • Mar 2019
    • 780
    Have tried a few files mainly on wood but find they don't last long, any recommendations.
  • Steven000
    • Aug 2018
    • 2829
    • Steven
    • Belgium
    Try to clean them with a wire-brush first, then they should work again for a while.
      • 18922
      Not sure what you mean Mark. Files should last forever, especially on a soft material like wood ? What exactly is happening? Can you post photos? it may be the file is too fine for the material, so try something coarser.
      If it is just clogging then Steven is right, clean them with something like a brass suede brush. You can also dust them with talcum powder before use to minimise build up.
      I would avoid using them on soft things like white metal though, that is quite hard to clean off.
      • Mini Me
        • Jun 2018
        • 10711
        Chalk is less messy than Talc and more easily handled.....build up is kept to a minimum and you will find that they will "chatter" less on hard materials. For best results clean them often as recommended above. Nicholson is a brand I recommend. I have some that are over 30 years old and they still cut like they should. Remember files only cut in a forward direction.....never draw them back over your work. Rick H.
        • GerryW
          • Feb 2021
          • 1757
          All depends on what type of file you're using - on wood, you need to use a 'rasp' which has very much coarser teeth, not a file designed for metal which have finer teeth (there are varying coarsenesses with both types).
          As said before, keeping them clean is a 'must'.
          For modelling plastics, I use a set of 'diamond' needle files - though shouldn't really, as they're really too coarse and I have to 'tone them down' a bit by using chalk and being very light handed when using them and finishing by using a scraper - been looking at a set of more suitable ones though.
          • GerryW
            • Feb 2021
            • 1757
            Unless using the technique of 'draw-filing' to polish the work, where you pull it along sideways - lost count of number of hours I've spent at a bench doing that!
              I have a set of these https://www.shesto.co.uk/na-1891?JFL6007
              and to care for them & other files/rasps I have
              • Bortig the Viking
                • Mar 2019
                • 780
                Thanks for the replies, the problem i have is that they seem to discolor and the teeth seem to disappear, not filing wood very well almost like its smooth, I think its because I bought a really cheap set.
                • GerryW
                  • Feb 2021
                  • 1757
                  Are the teeth missing from the file, or are they just clogging up after a few strokes?
                  Discolouration can just be the material that you're filing is interacting with the metal of the file, teeth breaking off is usually a sign of lower quality, as the teeth are hardened, but the file 'body' shouldn't be - on lower quality, normally they harden the whole thing, which makes the teeth brittle. (This is all from memory - about 50 years ago - so probably got some parts wrong!)
                  What I've said about the teeth, only relates to metal files - not to the 'diamond' ones
                  • GerryW
                    • Feb 2021
                    • 1757
                    Similar to mine, but I think mine are 'Amtec' and about £1.99!
                      • 15725
                      Coincidentally I have just bought THESE. Haven't had much chance to use them but they are a lot better than a real cheap set I bought at a model show years ago.
                      • GerryW
                        • Feb 2021
                        • 1757
                        I've got an odd one in the garage - wouldn't know where it came from, but it must be really high quality, still as good as it was years ago!
                          • 18922
                          Sounds like they might be just clogging up Mark. You might be better off using sandpaper or wet’n’dry paper stuck to thin section wood (or plastic) with double sided tape. It shouldn’t clog so readily and can be changed in seconds if it does.
