Metal tow cables
  • BattleshipBob
    • 6792
    • Bob
    • Cardiff
    Metal tow cables
    Evening
    The Dragon StuG G i am finishing comes with proper metal twisted tow cables, but they are very stiff and impossible to bend into realistic shape.
    Can i heat it up to give it the required moment??
  • scottie3158
    • 14199
    • Holbeach
    Bob,
    I would say yes but how are the ends secured? I would be careful that they don't unravel. Maybe localised heat where you want the bends
    • BattleshipBob
      • 6792
      • Bob
      • Cardiff
      Bob,
      Hi Paul
      I have attached the ends, so will try heat as you say where needed
      Thanks bob
        Are they steel cable? That looks great, but it’s hard to put it into realistic bends. I’ve long been using twisted copper wire instead.
        • BattleshipBob
          • 6792
          • Bob
          • Cardiff
          Hi Jakko, yes, they do look good but no flex at all!
            None at all, or they bend but don’t hold the bend?
            • GerryW
              • Feb 2021
              • 1757
              Sounds like they might be 'Bowden" cable (same as used on bicycle/motorbike brakes etc.) - unless going to heat up to red hot and form into the shape wanted, doubt that you'll be able to bend them
              • minitnkr
                Charter Rabble member
                • 7520
                • Dayton, OH USA
                Can you mount them in "ready service" mode? Like seen in Tiger I photos where they are attached at front & back same side so are put in service quicker. This usually requires a lessor bend. PaulE
                • BattleshipBob
                  • 6792
                  • Bob
                  • Cardiff
                  They look like bowdens Gerry, what a waste
                  Thats what i am thinking Paul, ta very much
                  • GerryW
                    • Feb 2021
                    • 1757
                    Bowden cable is cheap as chips - it's the barrels, nipples and adjusters that cost the earth! Used to have to make all my own cables for our bikes, as I'd alter the handlebars & couldn't get stock ones to fit.
                    • JR
                      • May 2015
                      • 18273
                      Photos Bob please, that might help to see exactly what your trying to work with. :nerd:
                      • BattleshipBob
                        • 6792
                        • Bob
                        • Cardiff
                        Here you go Mr Race
                        Yoy
                        You can see a tried bend! To fit on both fenders it has to go over, around etc!
                        • Strenko J
                          • May 2018
                          • 752
                          • Joe
                          • Pittsburgh PA
                          Bob,, Like Jakko, I've used copper wire twisted together and just cut off the ends, re-drilled them and some superglue to hold them in place, copper wire is easily bent to the shape that you want to achieve.. bummer on the fold in the pic you show..
                          • JR
                            • May 2015
                            • 18273
                            See what you mean Bob.
                            I've done wire rope splicing, one of the hardest things to achieve with out shredding your fingers !
                            Looks to me there aren't enough wires in the rope, 4 by the looks of it, in fact there should be at least 6 , some with a centre core again of 6 and others just the six.
                            I'd either make a new wire up using thin copper or heating that one up as was suggested.
                            453 Ex REME RECOVERY MECH
                            • BattleshipBob
                              • 6792
                              • Bob
                              • Cardiff
                              Hi John
                              Will try a heat up first, nothing to lose apart from the house lol
