Starting off my Grandsons
  • zuludog
    • Mar 2015
    • 239
    I would like to introduce my two Grandsons, aged 7 & 9 to plastic kits
    Do you think that is too young? Obviously they would have some help & supervision from me and their parents, though my daughter never made any kits, and my SIL just made a couple when he was a boy
    I would do the job properly, including teaching/helping them with glue, craft knives, acrylic paint, and other tools
    I did send the boys a couple of Airfix Quick Assembly models for Christmas a couple of years ago, and I hear that they enjoyed them very much
    Is the small Humbrol tool kit AG9150 any good? at least to get started, and I would add a few other items
    I've been browsing King Kit's website for cheap kits to start them off, and have seen Hobby Boss Easy Assembly and Starfix kits
    They don't seem to be very accurate, but for now that doesn't really matter, so do you think those kits would be OK to learn on?
    I'll post again when I've got my shopping list together, but in the meantime I would appreciate any other comments and advice
    Zulu,
    as long as they're closely supervised, and they want to make models, 7 & 9 is great.
    As for models - forget Starfix! they're poor and for a first model you want something that goes together well, and you end up with a good looking model! The HobbyBoss quick assembly kits would be ideal - even though they are simple to put together, they are detailed enough for any modeller!
    I made the Mitsubishi Claude - in 1/72
    ...and the P-38 Lightning in 1/48
    There are a a wide selection of HB easy assembly models, including Spitfire & Hurricane, and 50's jets
    As for tools the Humbrol kit looks OK, but remember - it has a sharp knife in it. Glue - I use Revell Contacta - it has a thin metal nozzle that doesn't squte everywhere!. Paints & brushes depends on the model - but go for Acrylic paints, they're eater based, easy to clean up & they don't smell!
    Any questions - ask away, we all started somewhere!
      No Zulu started 3 (now 4) of my grandsons Matthew Thomas & Samuel on the road. They have veered off now think girls etc.
      But one still has his Typoon WW11 on his shelf now 18. They were about same ages as your grandsons at that time.
      My 3 started on just ordinary kits with the paints & cement attached must have been Airfix stuff. 1/72 as there are not to many pieces need simplicity. All single engine less detailed. Just use all the stuff you have. Wait until they show a continuing interest before further investment in tools.
      First sleeves rolled up out of the way. Second a PINAFORE which wraps around. Third kitchen roll EACH..
      Put my three in the garage. Tell them it is cement not glue I did a short course or you will be littered with cement. Tell them to keep it out of their hair.
      Lots of argument on how does this go (chuckling away inside so funny). But also a lot of chat & laughter other times absolute quiet.. However they came back a second time to finish them off. Amazed as they were so interested & stuck to it (not literally :rolling. They cracked it & finished. There was some major differences in quality.. Interesting to see the characters in each showing thro. That will do, best possible persut of perfection.
      Last. Paint can get every where :tongue-out3: :cold-sweat:
      Best of luck Zulu Give us the low down on progress.
      • adt70hk
        • Sep 2019
        • 10400
        Hi zuludog
        As Dave has suggested so called quick build or easy build kits will be the way to go, especially for the younger one. My son was six when I started him on the hobby and the normal Airfix fair where too complicated for him.
        Airfix have just released a couple of these kits in 1/72. A Firefly and a Tiger I.
        There is also a company called the plastic soldier company which does a wide range of these sorts of kits that always contains at least 2 and normally 3 kits per box for around £20. The slight downside is that they don't come with any decals as there are aimed at wargamers who have a ready supply in the stash.
        There is also a company called Armourfast, which do super simple kits again aimed at wargamers. Currently going for less than £9 for two kits per box. Of the two to the plastic soldier ones are of a better quality and you often get more than one AFV option in the box.
        If you're interested in 1/72 AFVs have a look at this site.....https://henk.fox3000.com/index2.htm
        Good luck.
          If you go down the HobbyBoss route - this is what you can expect
Name:	spit in 01.jpg
ID:	1148597Click image for larger version
Name:	spit in 02.jpg
ID:	1148598Click image for larger version
Name:	spit in 03.jpg
          I just chose the Spitfire as one of the most recogniseable aircraft, at around £6 great value!
            • 15650
            As a teacher of primary age children for 35 years I would give some simple advice.
            Hard as it is try to only advise and support but let the boys do it themselves. They will make a mess, be impatient, get glue all over and you will cringe at the end product but it will be their's. Children need plenty of praise and encouragement for their efforts. I think it is wonderful to show youngsters that there is more to life than phones, TwitterTube and Facebox. :tongue-out3:
            All credit to you Granddad :thumb2:
            • adt70hk
              • Sep 2019
              • 10400
              [ATTACH=CONFIG]n1148600[/ATTACH]
              [ATTACH=CONFIG]n1148597[/ATTACH][ATTACH=CONFIG]n1148598[/ATTACH][ATTACH=CONFIG]n1148599[/ATTACH]
              That looks very good Dave, especially for only £6.
              • zuludog
                • Mar 2015
                • 239
                I just chose the Spitfire as one of the most recognisable aircraft, at around £6 great value!
                That looks interesting; where can you get it for £6 please?
                We lived in north west England, but my daughter & family now live in Dursley, near Gloucester
                Are there any model shops in the area please? Or anything else that might interest them. Thanks
                • minitnkr
                  Charter Rabble member
                  • 7510
                  • Dayton, OH USA
                  When I started my boys, we shared a bench until they got the hang of it. Yeah, girls & sports pretty much put an end to it although they both still appreciate the hobby. PaulE
                  • adt70hk
                    • Sep 2019
                    • 10400
                    Try HERE. Only £5 on this site.
                    As they're quite a niche product, it is highly likely you are either going to have to pay postage and packaging or you'll have to spend £7-8 without p&p.
                    Have a quick search on the internet for hobby boss easy assembly and you will come across plenty of sites selling them. Have a good search especially on places like eBay because occasionally you will come across a real bargain.
                    Hope that helps.
                    • Mini Me
                      • Jun 2018
                      • 10711
                      Hi Zulu.......I agree with Dave on the kit........at that age the less parts the better and the price is the other consideration. I wouldn't worry too much about "modeling tools" for 7 and 9 year olds, as a child all I wanted to do was get the parts of the sprue and get some glue on it so's I could stick it together. Don,t overwhelm them with sink hole puttying and such.....let 'em build and have fun. If they take an interest and start getting serious, then you will be able to introduce them to the "refinements" that go into building a better model than the last one. Keep it simple.......keep it fun! :thumb2: Rick H.
                        PM sent!
                        • Del640
                          • May 2020
                          • 1151
                          Having attempted my two sons into this at a similar age I have to say Laurie:
                          Nail.on.head.
                          Del
                            Nail.on.head.
                            Del
                            Del have you tried a surprise reward :tears-of-joy:
                            • Del640
                              • May 2020
                              • 1151
                              Ahhhh.... bribery..I like it!
