Annealing PE?
  • BattleshipBob
    • 6792
    • Bob
    • Cardiff
    Annealing PE?
    Now i know what annealing is ( not that thick, honest) but how hot and for how long??
    I have a lighter but not sure?
    Sorry if it seams a bit of a silly question
    Ta bob
  • Jon Heptonstall
    • 1704
    Hi Bob.
    A ciggie lighter works fine for smaller bits.It just needs to get red hot for a second or two.I only anneal for curvy bits.
    Jon.
    • BattleshipBob
      • 6792
      • Bob
      • Cardiff
      Originally posted by Jon Heptonstall
      Hi Bob.
      Jon.
      Thanks Jon
      Appreciated, bob
      • Mini Me
        • Jun 2018
        • 10711
        For Brass I wouldn't go to Red hot to anneal.......could cause sagging or deformation......for something this thin just the color change to dull red or even less is sufficient with a quick quench. Been annealing brass cartridge cases for years......Rick H.
        • BattleshipBob
          • 6792
          • Bob
          • Cardiff
          Many thanks Rick, very much appreciated
            If you don't have a ciggy lighter ( I ditched mine when I stopped smoking 20 years ago! ) I didn't - I bought some of these
            Made for lighting gas burners - you can get them at really cheap prices & are a lot more comfortable than a ciggy lighter!
            • stillp
              • 8090
              • Pete
              • Rugby
              Be careful that very thin parts don't overheat Bob. If you have an old PE fret you could put the part of the fret you want to anneal on top of a wide part of the old fret and heat that with your lighter.
              • Steve Jones
                • 6615
                JR invites Bob around for his latest PE annealing session
                • BattleshipBob
                  • 6792
                  • Bob
                  • Cardiff
                  [ATTACH]420149[/ATTACH]
                  Thanks Dave, got a ciggy lighter, never smoked lol
                  Thats a good idea Pete!!
                  [ATTACH=CONFIG]n1148839[/ATTACH]
                  Cracking, not yet hot enough!
                  • Mini Me
                    • Jun 2018
                    • 10711
                    Hey Steve, That looks like my place last Saturday night.......had the kids and grand kids out for a BBQ and a Bonfire.......no joke, at least that big. burned for 2 days. :thumb2: Rick H.
                    • adt70hk
                      • Sep 2019
                      • 10402
                      Count me in!!
                      • yak face
                        • Jun 2009
                        • 13829
                        • Tony
                        Might seem obvious bob but make sure you hold the pe with pliers , it conducts heat VERY fast !
                          Silly question.
                          Why do you anneal what difference does it make.
                          I have been using PE for 20 years. Should I change procedures ?
                          • yak face
                            • Jun 2009
                            • 13829
                            • Tony
                            Originally posted by Laurie
                            Silly question.
                            It makes it more flexible laurie - easier to fold box shapes and drape seat belts better . Done before painting so obviously not recommended for the pre painted PE frets ( eduard Zoom etc )
                              • 18892
                              It can also make some grades of brass too soft to work properly so It’s best to trial it first on scrap etch. I honestly think it’s only really of use on things like seat belts. If the brass is too soft it can make things worse rather than better....
                              Anything that has a regular shape or constant curve should be bent around formers. If you are likely to use a lot of etch brass in your modelling, the best investment you can probably make is a pair of high quality box jointed flat jawed pliers. Almost all of the small bends you need to make can be quickly and easily formed with them.
