Scale measurements
  • JR
    • May 2015
    • 18273
    Scale measurements
    Hello all.
    I have a scale 1.35 rule from RB, used many times. Today while measuring the opening for some gates I had a look at
    online scale length converter that calculates the actual length and the scale length according to the scale ratio. scale ratio could be set by yourself, supports different length units, including imperial units and metric units.
    Now when I measure with the rule against my normal ruler.
    The lower one and the scale version
    When I measure the scale length and put it into the conversion chart I get.
    Scale Ratio :
    Real Length mm cm meters km inches feet yards miles nautical miles
    Scale Length mm cm meters km inches feet yards miles nautical miles
    89 × 1 ÷ 35 = 2.5428571429 mm
    While using the rule it comes out at over 3 .010 mm .
    Any reason why and where am I miss using .
    Here is the photo just taken of the scale rule with the normal size showing the 89mm and the scale measurement.
    Confused to say the least with the scale converter.
    • 15696
    Hi John
    Can't help, sorry, but that Scale Conversion Calculator is really useful.
      • 18903
      To me, the ruler is incorrect. 89 mm divided by 35 is 2.54, as given by the calculator.
      if the answer was 3, as given by the ruler, then 3 x 35 should give you 89, which it obviously doesn’t. The scale ruler is actually giving you the scale distance for just over 105 mm. Are you sure it’s not actually a 1/30 scale rule?
      • scottie3158
        • 14201
        • Holbeach
        John,
        Download a free app called Hobby color converter. As well as having a really good colour converter it has an excellent scale converter as well.
        • boatman
          • Nov 2018
          • 14475
          • christopher
          • NORFOLK UK
          WELL TO ME John i was lost just reading it lol
          chris
          • The Smythe Meister
            • Jan 2019
            • 6248
            Hmmmm,Not sure what`s going on there John:thinking:,
            HOWEVER,Judging by the date on your Scale ruler,(Pre 2016)...... i`d say "BLAME BREXIT" ..........
            For everything else that goes wrong it seems to be the culprit these days!!:tears-of-joy::tears-of-joy::tears-of-joy:
            Andy
            • Steve Jones
              • 6615
              Ask me a question on golf :smiling5: :thumb2:
              • JR
                • May 2015
                • 18273
                Originally posted by Jim R
                Hi John
                That's what I've thought Jim, so judging by what Tim says and my own measurements the rule from RB is incorrect.
                My thought exactly Tim, its has printed on it 1/35 .
                John,
                Good idea Paul i'll look at that in a few minutes, thank you.
                chris
                :smiling3:
                • JR
                  • May 2015
                  • 18273
                  Andy
                  Now that's a thought so using the compound interest rate divided by 25 x 12 x 135 it works quite well .I blame the French .
                  • JR
                    • May 2015
                    • 18273
                    And camo , small rivets and anything to do with PE.:smiling2:
                    • boatman
                      • Nov 2018
                      • 14475
                      • christopher
                      • NORFOLK UK
                      :thinking:OH GOD he;s orf again lol:rolling::nerd::upside:
                      chris
                      • minitnkr
                        Charter Rabble member
                        • 7538
                        • Dayton, OH USA
                        Mark 1 eyeball works just fine. If it looks good it is good.:smiling:
                        • JR
                          • May 2015
                          • 18273
                          Agree with you on that Paul, I also used a figure when doing door ways.
                          • adt70hk
                            • Sep 2019
                            • 10409
                            John,
                            Sorry can't help but have enjoyed the humorous posts nonetheless!!
                            ATB.
                            • monica
                              • Oct 2013
                              • 15169
                              I,m with Chris,[ boatman ] on this one as well never been good at working them out and have
                              over the years ask for some help ,just don,t get my head around it, :disappointed2:
