Thanks Laurie. You have some great displays and a nice workspace.
You make a good point about a window and dust but you do need good ventilation so there is a balance.
I am planning a large enough build area to give me plenty of build space with my HobbyZone modules surrounding it. I will have a spraying area separate away from my build area. I will have to vent through the window, which will need to be open a crack while I spray. I will minimise blown on dust by how I position the booth and I will vacuum regularly, certainly before I spray.
In theory I am fortunate in that I will have fresh sea air relatively free from dust and pollen. I say in theory because there is a fair bit of development going on in the Port currently (that will actually benefit me!) so I do expect some dust from that. There is the main access road to the Docks nearby but that is the opposite side and not right up close so any pollution from that should not be blown in and, anyway, prevailing winds tend to be from the sea.
As for light, you are correct but I will make sure I have plenty of task lighting in the right positions.
Been busy ordering broadband today and have been looking at options to buy an ‘off the shelf’ workbench solution rather than book a carpenter and wait for him. It does look as if there is a good option. No decisions on that yet as I will need to check measurements ‘in situ’.
