Removing seams off funnels?
  • BattleshipBob
    • 6792
    • Bob
    • Cardiff
    Morning all
    Just started the funnels on Tashkent, i have a flexi file but after what seems a lot of sanding the seam is still visable. Am i doing this right??
  • boatman
    • Nov 2018
    • 14477
    • christopher
    • NORFOLK UK
    Morning all
    WELL Bobm8 if i was doin it id file off the worst of the seam then get some very fine wet an dry sandpaper an sand it down usein water to clean out the sand paper an your seam should gradually go so its so smooth not to notice but again Bob just try your best as noone can ask for more hows that but the other members may have their ways of doin it
    chris
    • BattleshipBob
      • 6792
      • Bob
      • Cardiff
      Morning Chris, biggest fear is losing the curve of the funnel!
      • dalej2014
        • Aug 2021
        • 507
        I'd scrape off the worst of the flash with a knife blade (adzing the flash) then move onto wet and dry, very fine grit - 1500 to 3000. If the seams don't quite match up you may need to lay a very thin bead/sausage of fine putty along the two edges, then adze and sand. It's a tedious job, but makes a massive difference to the finish. Best of luck.
        • boatman
          • Nov 2018
          • 14477
          • christopher
          • NORFOLK UK
          YES i see what you mean Bob m8 but then dale thinks like me in my answer so there you go you have your answer so get stuck in lol
          chris
          • Mark1
            • Apr 2021
            • 4156
            What your sanding with should have a hard surface,anything soft will ride over the shape of the seam
              Is it only visible, or can you also feel it with your fingertip and/or fingernail? If you can’t feel it, you probably won’t see it either once a coat of paint has gone over it. Which is the best way to check, by the way: paint the seam and its immediate surrounding area.
              • BattleshipBob
                • 6792
                • Bob
                • Cardiff
                Many thanks Dale
                Thank you Mark
                Thanks Jakko
                Have read that if you run a marker pen over the seam and then sand until the pen mark goes??
                • BattleshipBob
                  • 6792
                  • Bob
                  • Cardiff
                  Not many seams on a StuG lol
                  Always thought you had to sand until the seam line has gone??
                  • boatman
                    • Nov 2018
                    • 14477
                    • christopher
                    • NORFOLK UK
                    WELL Bob m8 if you keep sanding you will go right through but do as dale has said with sandin then build it up with putty to retain your funnel roundness is the way to go
                    chris
                      • 15697
                      Jakko is right. Sand until it feels smooth. The line in the plastic may well still be visible. Priming that area will show whether the seam is still there. If you do find the seam needs filling I paint Mr S 500 along it and then sand again.
                        • 15697
                        With a StuG all problem areas can be dealt with with a liberal application of mud glorious mud. Mud halfway up a warship's funnel however just wouldn't work. :rolling: :hungry:
                        • Steve Jones
                          • 6615
                          If you sand in a circular motion it reduces the risk of mishaping the area
                          • BattleshipBob
                            • 6792
                            • Bob
                            • Cardiff
                            chris
                            Thanks Chris, will not use the black an decker then lol
                            Thanks Jim, appreciated
                            Bugger thats, that idea down the plug hole lol, luv mud!!
                            Lovely, thanks Steve!
                              • 18905
                              Hi Bob. On a curved surface the best way to sand a seam is to sand wet at 45 degrees to that seam. That will minimise the possibility of thruppenny bitting the part, ending up with flat spots. It’s standard practice in model railway loco building to ensure the boiler remains round.
                              Your idea of marking the seam before work is a good one, but if there is an appreciable cavity in the seam I would fill it first.
