Three stage clean…..
1. Dust with a soft brush to remove all loose material.
2. Damp brush using a soft brush moistened (damp, not wringing wet) with a mild dish soap solution. This should mobilise the greasy component of the dust. Rinse and remoisten the brush regularly during this stage or you’ll give the model an all over coat of crud.
3. Damp brush with a soft brush moistened with clean water to remove the dish soap and dirt. Again rinse and redampen the brush regularly. This strange may need repeating a couple of times to remove all the crud.
For any stubborn areas repeat stages two and three as required.
I used to do this with my models every couple of years until I got some glass fronted cabinets.
