After very small files?
  • BattleshipBob
    • 6799
    • Bob
    • Cardiff
    Afternoon all
    I am looking for very small/fine files, escapement ones? A set is expensive but found a 2.3mm round file on evibay, has anybody else bought these??
    I have removed the anchor chains from Graf Spee and have drilled out the holes in the deck for the chains, however they are slightly oval. I have the generic set of diamond micro files but they are too big!
  • adt70hk
    • Sep 2019
    • 10409
    Sorry Bob can't help. Hope you get it sorted.
    ATB.
    • minitnkr
      Charter Rabble member
      • 7541
      • Dayton, OH USA
      I've used drill bits in a pin vise.
      • BattleshipBob
        • 6799
        • Bob
        • Cardiff
        New to me lol, thanks for that!!
          • 18907
          Something like this might help Bob
          Needle files are also known as Swiss Pattern or Jeweller's files. These small files are very accurately made and designed for precision work or delicate small work. Overall length is approximately 155mm. Also available is the 300189 universal needle...
          However, I would check with them to make sure it’s fine enough.
          Edit, according to the questions section it goes down to 1.2 mm
            • 18907
            Another option is this…
            Ive used them for years. Saves a fortune on miniature drill breakage….
            • BattleshipBob
              • 6799
              • Bob
              • Cardiff
              Many thanks Tim, have messag them
              • BattleshipBob
                • 6799
                • Bob
                • Cardiff
                Found another modelcraft set 0.6 to 2mm, that will do the jobs
                  • 18907
                  There are lots about Bob. Mine are designed to be used in pin vices, but they pre date the modelcraft ones by many years
                  The advantage of broaches over needle files when enlarging holes in sheet stock is that a five sided broach won’t drift off centre. If you do go down the file route you will find that simply rotating them anti-clockwise will do what you want. If you rotate them clockwise they wind into the hole like a drill and bind. Personally, I would aim to get both because in my opinion they are both very useful tools :thumb2:
                  • BattleshipBob
                    • 6799
                    • Bob
                    • Cardiff
                    Thanks Tim, do not use many files but will get the broaches to do the anchor hole
