Mini F Clamps
  • Mr Bowcat
    SMF OG
    • Dec 2016
    • 4600
    • Bob
    • London
    Mini F Clamps
    Morning all.
    For some time I have been after some small friction clamps like these from ModelsRGo.
    Unfortunately this company seem to have closed down some time ago and the clamps are like the proverbial hens teeth. I wanted some as they would be useful on occasion when you want to hold something together but not exert spring clamp pressure, for example when holding an aircraft fuselage together for gluing. The advantage of these clamps is that with only friction holding the jaws together they can be adjusted to just light finger pressure.
    Every now and then I have a look online to see if any have become available or if anyone else has started making them, but to date no joy. So I decided to make one to see how difficult it would be. Turns out, not that difficult at all. This one is only a prototype with materials I had to hand, I will test it out and if it works OK will make some more, possible using aluminium for the jaws.
    No doubt for anyone with a 3D printer this would be a simple job, it took me a couple of hours in my workshop with a pillar drill, a bandsaw and a lathe.
    Si vis pacem, para bellum.
  • adt70hk
    • Sep 2019
    • 10404
    That's brilliant. Very well done.
    • stillp
      • 8090
      • Pete
      • Rugby
      Well done, but wouldn't these do? https://www.scalemodelshop.co.uk/pro...lcraft-cl8720/
      • Mr Bowcat
        SMF OG
        • Dec 2016
        • 4600
        • Bob
        • London
        I have looked at them Pete, they appeared (to me) a bit flimsy compared to the ModelsRGo version.
          • 18895
          Hi Bob. Nice ingenuity there, but they remind me of something….
          Have you looked at toolmakers clamps, like these?
          Craft Tools and Hobby Tools from Proops Brothers Ltd. Browse a vast range of tools for craft & hobby, DIY, model making, jewellery, metal & wood working.
          • Mr Bowcat
            SMF OG
            • Dec 2016
            • 4600
            • Bob
            • London
            Cheers Tim.
            Yep, I have considered making tool makers clamps. Because they work on a thread, if the thread is fine enough you could get some very fine control on them. Couple of potential issues, one they tend to me made entirely from metal so may be a bit heavy for modelling work, and two, they are a hell of a lot more complicated to make. :tears-of-joy:
              • 15675
              Hi Bob
              Clever stuff. Should be useful. I suppose a big issue is the weight of the clamp especially as you only want to clamp gently, the heavier they are the more likely they may be to slip off.
                • 18895
                I’ve got a couple of pairs of these sort of clamp for that sort of job Bob….not silver line, but similar design. I picked them up at model shows ages ago.
                They are quite sensitive to be honest, and can be tightened with one hand. I’ve used them for aircraft fuselage assembly several times. I don’t use them often, but they are really useful when I do.
                • Mr Bowcat
                  SMF OG
                  • Dec 2016
                  • 4600
                  • Bob
                  • London
                  Cheers Tim.
                  I've considered that type, always been worried of overtightening and causing damage.
                  • stillp
                    • 8090
                    • Pete
                    • Rugby
                    Originally posted by Jim R
                    Hi Bob
                    I'm sure I've seen plastic ones.
                    Looking for those I came across these: https://www.proopsbrothers.com/model...rge-3092-p.asp
                    • wotan
                      • May 2018
                      • 1150
                      Bob
                      Maybe a problem with postage costs but Micromark have these;
                      Priced at $16.95 for the four.
                      • Mr Bowcat
                        SMF OG
                        • Dec 2016
                        • 4600
                        • Bob
                        • London
                        Cheers gents, looks interesting.
                          • 18266
                          Noooooo dont go there! I got given some a few years back. A very clever idea and they can push apart as well as clamp together. The grippy bits are nice and soft and conform well.
                          BUT the second you clamp something the designs weakness becomes apparent. Due to the single connection rod the clamps twist round and fall off. If they have the two rods like the one you made Bob they would be great. But a clamp that cant clamp is a worthless heap of oop:.
                          For the intended use, I would think that some plastic profiles, a few bits of tube and a rod that fits the tube and you could knock them out easy....
