Etch Help please.....
Another thing that may help is to use a tiny bit of PVA glue,or even spit,to hold the part in place before applying the CA.
Jon.Comment
If you do use a fibre pen use it wet! I always dip the fibre pen in a saucer of dilute washing up liquid before use. It stops the fibres flying. I would still wear a mask though, the fibres are horrible. I would also cover my worktable with a sheet of news to aid clean up.
I don’t do much etch these days, but when I did I mostly soldered it. Obviously this is only any good when sticking etch to etch
For fitting etch to plastic small bits get superglued, and large bits get stuck on with epoxy, usually held in place while it dries with tacks of superglue.Comment
Forgot to say, when using superglue I always put a scrap of double sided tape on a block, leaving the waxed paper on it. Drop the superglue on it and it remains workable for ages if you transfer the glue to the joint with a pin.Comment
I`ve got some PVA glue for sure...... and i`m PRETTY confident that i can get some spit from somewhere!!:tears-of-joy:
AndyComment
Great tips from you also.... especially the one about not soldering the etch to plastic:thumb2::tears-of-joy:,
Thank you very much mate.... "double sided sticky tape"... Genius idea.
AndyComment
What a great day on the forum….I was earlier told I was right, and now I’ve been accused of genius. Would that all days were like this LOLComment
Cripes I'm a slob never washed photo etch or kit parts let alone all this ruffing up the surfaces stuff but hey work's for me ,but for what its worth I use two of the super glues from Deluxe the yellow labled one gives five to ten seconds grace the blue lable a gel one ten to twenty plenty of fiddle time ,I also find its easier to put a tiny dot on the kit where the peice is to be fitted this I'll do with old scaple blades ,cocktail sticks ,piece of old sprue sharpened to a point ,syringe needles (also good for drilling out small barrels or use as a bradle to make sure you start drilling in the right place)old airbrush needles loads of stuff you can use as a aplicator. I'm with Steve with the lid thing bisto lids as Steve said pringles lids the good thing is when there's no space left flex the lid all the hard bits of glue just pop off leaving you to start again. Just remember less is more a small dot glues as good as a blob ,that's like me but with a s. DaveComment
All covered above but to hold some really small parts is have them on a bit if blu tac on a tooth pick. To stop shacky hands try as much to tack the parts down with tape or a pair of extra hand clips then apply the CA carefully not touching the tape or blu tac.
RichardComment
For some parts on AFVs, eg tool clamps and mesh, I use an AK chemical that blackens the brass; that way interior surfaces of the clamps, or chips and scratches acquire a 'natural' appearance without too much work!
SteveComment
But also makes the bond weaker, because it prevents the glue from forming very long polymers. Breathing on superglue has much the same effect, though not as quickly: superglue sets through the action of water vapour in the air, so if you breathe out onto drying superglue, you speed up its setting. But again, this weakens the bond compared to letting it dry normally.Comment
