Scribers
  • Mickc1440
    • 4775
    Scribers
    Dear all
    Looking to add a scribing tool to my collection of tools. The last one I got from flea bay was next to useless. What do you guys recommend please?
  • AlanG
    • 6296
    Tamiya all day long
    • scottie3158
      • 14201
      • Holbeach
      Agree with Alan, I have a Tamyia scriber and it's never let me down.
        • 15681
        Although Tamiya are expensive, maybe overpriced, their tools are very good so I'm another who would recommend Tamiya.
          • 18901
          Depends on what you are scribing Mick. If you are using it for marking out I’d go with one from Eclipse tools. They sharpen beautifully and hold their point forever.
          For cleaning out panel lines, scribing plank lines, etc. I would also go with the Tamiya, though it’s really a scrawker (it’s to do with the cutting edge), not a scriber
          Best thing about the Tamiya type is that they cut material out rather than just pushing it to the side, so don’t leave a raised edge either side of the line.
          • Mickc1440
            • 4775
            Many thanks for the suggestions gents, it’s needed for mainly cleaning up panel lines etc. Time to shop
              I’ve got a Trumpeter one, which works fairly well even if it feels a little cheap. But that’s probably because it was
              • Airborne01
                • Mar 2021
                • 3964
                • Steve
                • Essex
                Tamiya - all day long! They are re-branded Olfa tools and they are superb!
                  I have one of those too, but got the Trumpeter scriber because it’s smaller and finer. The Tamiya one, I use mainly as a plastic sheet cutter rather than for scribing lines.
                  • JR
                    • May 2015
                    • 18273
                    Do I need one ? No not a joke , would it be any use on armour and the like.
                    I rarely do planes .
                      • 18901
                      Only if you do a fair bit of scratchbuilding or build planes John. I haven’t used either of mine (I have a Tamiya one for re-scribing panels, and a bigger one from Wikes I use for cutting thicker plastic sheet) for a long time.
                      • JR
                        • May 2015
                        • 18273
                        Thanks Tim, as you know planes aren't my thing , do use some plastic card so might be ok for marking that . What about as a tool for foam board , don't want something too sharp but capable of of doing an imprint say for mortar lines , that sort of thing .
                          • 18901
                          Not the tool for that John.
                          They basically cut a square shaped furrow in plastic, but leave no furrow at the sides of the cut. They work best on harder material This sort of sort of scriber would probably just tear foam board, so will not be really useful there. They are very good for making plank lines in plastic card though.
                          Conventional pointed scribers cut a V shaped furrow leaving ridges either side of the cut, rather like a field plough.
                          By the way, the best way to cut plastic card (especially the thicker sheets) that I’ve found is to score the line with a sharp knife and then snap the sheet along that line. Usually just known as score and snap….
                          • Mini Me
                            • Jun 2018
                            • 10711
                            A question for all you Tammy lovers............what is the narrowest line you can scribe with the Tamiya scriber? Would it work in 1/87 scale or produce too wide of a line? TIA :thumb2: Rick H.
                            • yak face
                              • Jun 2009
                              • 13836
                              • Tony
                              As mentioned above the Tamiya one is a rebranded Olfa P cutter , but cheaper in the Tamiya packaging . Ive got the Olfa version and its a great tool , useful as a scriber and also a cutter too ( i used mine to cut out the tail hook section on the airfix sea hurricane ) . Sometimes its a bit too effective , cutting quite deep on the first pass so like Jakko ive got the trumpeter one too for shallower scribes. Also being from Sheffield of course ive got a couple of Eclipse pocket scribers too .
