PE and burnishing
  • BattleshipBob
    • 6792
    • Bob
    • Cardiff
    PE and burnishing
    I have recently burnished the railings on Graf Spee and are doing prep work for KGV. I have two large PE sets ( my god looks scary to me ) now I will clean with IPA but should I burnish the sets as well??
  • Isitme
    • Nov 2020
    • 795
    Bob, turn the sheet over and use some 600 wet and dry to just wipe over the surface GENTLY, this will give you enough rough for the c/a to grip. Hope this helps. Mike.
    • BattleshipBob
      • 6792
      • Bob
      • Cardiff
      Thanks Mike, can see the point of burnishing ship railings but not the usual PE sets?
        • 15696
        I know that glass fibre pens can be unpleasant things - little bristles can break off but I go over both sides of the fret. I do take precautions, gloves, mask and a hoover of the bench - usually :rolling:
        • BattleshipBob
          • 6792
          • Bob
          • Cardiff
          Thanks Jim, have one and painful when it fights back lol
            • 18903
            Use it wet. Keep a small dish of diluted washing up liquid and dip the glass fibre pen in it every time you use it. It stops the fibres flying around.
            • BattleshipBob
              • 6792
              • Bob
              • Cardiff
              Many thanks Tim
                • 15696
                What a good idea. Another example of a simple idea that works. Thanks Tim.
                  • 18903
                  I’d still wear gloves and a mask though Jim. I hav used one much recently, but when I did I’d cover my bench with a couple of sheets of newspaper. Clean up was then just a matter of scrunching up the paper and sticking it in the bin.
                  • RonGlass
                    • 801
                    Sorry but what is IPA ? I'm not familiar with that term thanks
                    • stillp
                      • 8093
                      • Pete
                      • Rugby
                      Isopropyl alcohol Ron. Sometimes known as rubbing alcohol.
                      • RonGlass
                        • 801
                        Thanks Pete !
                          • 18903
                          Originally posted by RonGlass
                          Thanks Pete !
                          Also stands for India Pale Ale Ron, but not in this context LOL…..
