Decal fix on acrylics.
  • itzed109
    • Mar 2022
    • 8
    I am new to modelling, and since I am young, I do not have much money to buy stuff with. So I was wondering if using a small amount of humbrol decal fix on acrylic paints would work, or if using a bit of water to dilute the humbrol decalfix. Or should i just buy microset and microsol?
  • stillp
    • 8096
    • Pete
    • Rugby
    Decalfix is OK, but I've found it can make the decal difficult to slide, so you have to position it right first time. It should be fine to apply it after the decal is placed, or it might be easier if diluted with water as you suggested - I haven't tried that.
    • Gary MacKenzie
      SMF Supporter
      • 1057
      • Gary
      • Forres , Moray , Scotland
      I have used decal cote on top of acrylics. I believe it's the older version of decalfix, mine still has the price of 80p per bottle.
      • Mark1
        • Apr 2021
        • 4156
        I've used decal fix on revell acrylics with no issues but have found the revell paint to be pretty resilient ,couldn't comment on other paint brands as I now gloss varnish before decals go on and now use vallejo acrylics. I use acrylics for washes over varnish and clean up with a mix of water and decal fix as the acrylic washes can dry a bit quick and this helps remove the excess.
        • itzed109
          • Mar 2022
          • 8
          so does that mean that the acrylic paint won't come off when using the new decalfix?
          • itzed109
            • Mar 2022
            • 8
            Originally posted by Mark1
            I've used decal fix on revell acrylics with no issues but have found the revell paint to be pretty resilient ,couldn't comment on other paint brands as I now gloss varnish before decals go and now use vallejo acrylics. I use acrylics for washes over varnish and clean up with a mix of water and decal fix as the acrylic washes can dry a bit quick and this helps remove the excess.
            Do you know what would happen on tamiya acrylics?
            • Mark1
              • Apr 2021
              • 4156
              I couldn't tell you! I would suggest try a small test area on the model somewhere that wouldn't be seen.
              • itzed109
                • Mar 2022
                • 8
                yep i will do, thanks for your help!
                • stillp
                  • 8096
                  • Pete
                  • Rugby
                  I don't think Decalfix would affect any acrylics.
                    Edward,
                    I've used Decalfix on all sorts of acrylic paint, Vallejo, MiG Ammo, AK, Hataka with no effect on the paint - but Decalfix can be very harsh on the decal itself! I tend to put the decal on using 50/50 diluted fix, then when I've positioned it use neat fix over the top!
                    • adt70hk
                      • Sep 2019
                      • 10419
                      Edward
                      Can only echo what Dave said re Decalfix.
