One off Decal set.
  • Roadie
    • Mar 2022
    • 63
    One off Decal set.
    Can anyone put me in the direction of a sheet of Decals, Letters and Figures only in White.
    Have a project coming up where the paint job and Decals are my doing only.
    All I want is various numbers and letters in white that I can make up myself. Probably approximately 3/16” in height.
    Only letters needed are R,A,F,T,Y,P,E,M&U plus numerous numbers.
    Thanks SteveClick image for larger version
    You can get generic white serial numbers/ letters
    The only thing you have to do is work out what size you need for your scale! ( not as easy as you think! )
      • 18269
      Last time I purchased some the full size was indicated by the side of the decals. So as long as you by for the right scale you should be OK.
      • rickoshea52
        • Dec 2011
        • 4076
        • Rick
        Have a look at Fox Transfers too.
          The right size for a vehicle like that is 3½″ (89 mm) high and 2½″ (64 mm) wide, with strokes ⅝″ (16 mm) thick in the real world. Just divide those by the scale of the model you’re building and you have the size you need for a model.
          And the typography geek in me wants to mention that the text and number on the door, are in too modern a typeface — that is, Helvetica, which first of all didn’t exist yet for much of this vehicle’s active service, and second, wasn’t normally used by the British military even when it did exist. But modern vehicle restorers often do use it, because you can buy it in self-adhesive form
          • rtfoe
            • 9084
            And the typography geek in me wants to mention that the text and number on the door, are in too modern a typeface — that is, Helvetica, which first of all didn’t exist yet for much of this vehicle’s active service, and second, wasn’t normally used by the British military even when it did exist. But modern vehicle restorers often do use it, because you can buy it in self-adhesive form :smiling3:
            That's Helvetica all right, a sans serif type. I always prefer Goudy...much softer serif type.
              Goudy Old Style? That’s not really suitable for most vehicle markings, though
              Anyway, the thing with markings from before about the 1960s, though, is that many of them were hand-painted by crew members with the necessary skills. Which is to say: no modern font will match them, because the glyphs were essentially at the whim of the painter.
                • 18269
                Important info needed to give the best reply.
                What scale is the model.
                Are you doing a replica of the wonderful truck as in the photos
                Are you doing a version as it would have been.
                Phew!
                if as in the photo the 'modern' letters are fine as it is what they are. If going back to early days then most likely stencils are the way to go, as they have used on the bonnet (hood) motor cover... what ever. (Here its a motor helmet lol.)
                Number plates would, if applicable, stamped and painted.
                • rtfoe
                  • 9084
                  Goudy Old Style? That’s not really suitable for most vehicle markings, though :smiling3:
                  I know...they're for my Ads not kits. Besides Stencils...Futura can be used for WW2 vehicles.
                    That’s why I mentioned the official number sizes in the British Army (Which apply to the Second World War and immediate post-war era, I should add.)
                    Good point. If the plan is to build a model of the restored vehicle in the photo, then Helvetica is not just fine but the best choice
                    Sort of … I would use a condensed version of it as a reasonable match for typical British numeral style, but it’s not like the British Army used that actual typeface on its vehicles. The German air force, though, did use it — just not on vehicles, but for its manuals
                    [ATTACH]451493[/ATTACH]
