Light direction from a window
  • BattleshipBob
    • 6792
    • Bob
    • Cardiff
    To keep my mind off what's going on I am working on the layout of my proposed garage modelling room.
    Its a typical garage with a window on one side of the side walls.
    Am I right in saying that the bench should be at right angle to the natural light?? There will be plenty of room for a long bench but much of it would not have natural light
    • 18901
    I must admit that both of my dedicated rooms (old house and new house, I don’t have two rooms) had light at right angles to the bench, but both were south facing. If your window is north facing I’d put the bench in front of it. You will get the best light without glare. It’s why factories had northlight roofs. The only thing you don’t really want is direct sunlight on the bench.
    • BattleshipBob
      • 6792
      • Bob
      • Cardiff
      Hi Tim, windows roughly North west
        • 15686
        North West should mean that you get good light without the glare from direct sun. My bench is along the window which faces north east.
        • BattleshipBob
          • 6792
          • Bob
          • Cardiff
          Sorry, so you mean you work with the light directly in your face, sorry to sound a tad thick lol
            • 18901
            You should only get direct sunlight late in the day in Summer Bob. I would expect that to be fine. To be honest, if the light is too bad for glare on the few days we get direct sun you can always put up a cheap blackout blind. Decent bench lighting will eliminate shadows anyway.
            • BattleshipBob
              • 6792
              • Bob
              • Cardiff
              Thanks Tim, I might put the bench for spraying/painting at a right angle to the window and the modelling bench in front of the window, will measure in the morning, got my builder mate coming tomorrow
                • 18901
                Good stuff. Excellent ambient lighting is more important than where the window is to be honest. However, make sure your lighting is daylight rated or all your painting will be “off”.when you take it somewhere else
                  • 15686
                  Hi Bob
                  A picture speaks a thousand words.
                  I only get direct sunlight very early in the morning in summer for an hour or so.
                  • BattleshipBob
                    • 6792
                    • Bob
                    • Cardiff
                    Lovely room Jim, many thanks for taking the time. That's answered my question perfectly
                    • Mini Me
                      • Jun 2018
                      • 10711
                      Hi Bob
                      [ATTACH=CONFIG]n1178824[/ATTACH]
                      Oh My!!!! a Tidy Bench Club Member...........
                      • Jack L
                        • Jul 2018
                        • 1270
                        • Cheltenham
                        Hi Bob
                        I have never seen such clearly defined carpet monster tracks in a modelling room before!
                        • BattleshipBob
                          • 6792
                          • Bob
                          • Cardiff
                          Yep, Jim's one lucky boy!
                          Also thinking of going into the loft, that would be better than the garage but more expensive of course
                          • adt70hk
                            • Sep 2019
                            • 10409
                            Hi Bob
                            [ATTACH]456701[/ATTACH]
                            Lovely room Jim, pleased to see I'm not the only one who uses newspaper to line their spray booth.
                            • boatman
                              • Nov 2018
                              • 14455
                              • christopher
                              • NORFOLK UK
                              Hi Bob
                              COR jim i can see the reason you are the boss of the TBC do you ever use it lol
                              chrisb
