Looking to upgrate the radiator mesh . has anyone done this and what size did you use? Any help greatly appricated. Regards mark
What size mesh for 1/12 scale Bentley blower
I know next to nothing about this car, but if all else fails, you can count the holes to work it out:
I recommend using the counting tool in Photoshop -
From another forum
"I'm making steel mesh from a sheet of mesh I found in a glass fibre repair kit, the mesh size is pretty much spot on, made a grille, headlamp covers and now making a carb cover that's not in the kit. "Comment
Oh, hang on, you’re asking for American mesh sizes … as Ian indicated above, in Europe you’d just buy mesh with 1 mm spacing, so that’s the most likely answer you’re going to get here. A quick bit of googling turned up this page which says that 1 mm mesh is US size 18 (it says 1000 μm there, but that equals 1 mm).Comment
