What glue?
  • JR
    • May 2015
    • 18273
    #31
    Originally posted by Jakko
    No, this:
    [ATTACH=CONFIG]n[/ATTACH]
    According to the MSDS, it’s basically 25–50% naphtha, 10–25% ethyl acetate, 10–25% more naphtha (but treated differently from the other), 10–25% methyl ethyl ketone (MEK), <1% n-hexane and <1% cyclohexane.
    The kind of glue used for plumbing pipes is normally thick and gloopy, AFAIK, and applied with a stick or a spatula — not the kind you’d want to use on a model kit I think :smiling3: But if you happen to come across an opened jar/tin/etc. you could always take a peek at what it’s like, I suppose.
    As I said to Tim my Plumber used that sort, I never really looked as he was gluing pipes. Still interested in finding something like that here.
    • Bugatti Fan
      • Mar 2018
      • 314
      #32
      I use Revell Contacta a lot. Discarded the plastic cap and keep a small straight length of 0.5mm brass wire constantly in the tube end to keep it clear. Sometimes it clogs a bit whilst in use but I just wipe the tube towards the end with thumb and finger and use the wire to clear it when it happens.
      Beading wire or a thin pin might be alternatives to what I use.
      • Modler bob
        • May 2022
        • 277
        #33
        Cheers for all the replies.
        I'm using the contacta glue, and it's been ok so far, only had to burn the needle once.
        I try to put the cover on straight away, I guess that helps.
        Just the putty I have to get used to. :smiling3:
        • BattleshipBob
          • 6792
          • Bob
          • Cardiff
          #34
          Very late to this discussion, got a good excuse!
          I like Tamiya extra thin, but it's a bit smelly and gives me headaches
          So after trying some other makes found this
          Comes in different colours, is very thin and flows very well plus low smell!
