Fitting metal barrels to a ship?
  • boatman
    • Nov 2018
    • 14455
    • christopher
    • NORFOLK UK
    #16
    Wow - brave people using power drills for plastic! I wouldn't trust myself, I use a hand pin chuck, and drill very slowly!
    yes i see your point Dave but ive managed to drill plastic on my power drill severall times as it ok if done gently
    chrisbmtb
      I'd rather spend 5 minutes drilling a hole by hand, than 20 minutes doing repairs with filler
      • boatman
        • Nov 2018
        • 14455
        • christopher
        • NORFOLK UK
        #18
        WELL so far Dave i havnt had any probs
        chrisbmtb
        • Andy the Sheep
          • Apr 2019
          • 1864
          • Andrea
          • North Eastern Italy
          #19
          Have seen a tamiya handy battery drill bring used, nerves of steel. Not me, as you say Dave pin chuck!
          Not really, Bob: copper nerves will do the job perfectly :tongue-out3: .
          The Tamiya drill you mentioned works at low speed and it's easy to handle as it's like a small pistol (e.g.: a Beretta 34 or Walther PPK if you are a Bond fan ).
          I find it easier to handle that than a hand pin vise, but I'm pretty sure this depends on how poor is my handling of a pin vise.
          Andrea
          • Allen Dewire
            • 4741
            • Allen
            • Bamberg
            #20
            Afternoon Bob,
            The guys have given you a lot of good info here and it should help with the metal barrels. You probably have about 20 float thingy's in the stash and and I would think you will also have to drill out portholes and other barrels and the like. You need something that will do these jobs quickly and efficiently without any stress. You could drill them out by hand, use a little electric drill OR you could stop playing around and get one of these,
            The table is fully adjustable so you get the perfect depth every time. you can change the chuck and use bits down to 0.2 mm for the little jobs. 50 portholes drilled out in 5 minutes without getting cramps in your fingers. Has a handy lamp so you can always see what you're doing. It would fit in the corner of your new shed and not take up too much space. Yea, it's a bit pricey, around €1800.00, but think of all the years use you will get from it with no cramps in the hands. Just my 2 Pfennings worth Buddy and food for thought....
            Allen
            PS, It would also have many uses for building StuGs when you start up again 10 years from now......................
              • 18901
              Hallelujah brother….testify!
              • boatman
                • Nov 2018
                • 14455
                • christopher
                • NORFOLK UK
                #22
                Afternoon Bob,
                [ATTACH=CONFIG]n1182519[/ATTACH]
                Allen
                WELL Bob my upright drill is very similar but not as big an the chuck will hold a 1mm drill bits up to 5/8 th drill bit from my micro drill bit case an it only cost about 35 quid from B& Q dont know where allen bought his at 1800 euros wow
                chris bmtb
                • BattleshipBob
                  • 6792
                  • Bob
                  • Cardiff
                  #23
                  Andrea
                  Hi Andrea, have looked at the tamiya drill, I think the smallest drill bit it takes is 1.0mm? Not sure if I will need one that much to be honest?
                  Afternoon Bob,
                  Allen
                  Afternoon Allen, lovely bit of kit but a but expensive for the use it would get, thanks for the info
                    Seriously, though, if you happen to know someone who has a table drill that you can use occasionally, it can come in very handy for certain jobs when building models, like this for example:
                    I wouldn’t have wanted to try opening a 5 mm hole up to 9 mm, eighteen times, either by hand or with a hand-held drill, so my father’s table drill was very useful.
                    • Andy the Sheep
                      • Apr 2019
                      • 1864
                      • Andrea
                      #25
                      Bob, I use the Tamiya drill with bits down to 0.3 mm. For larger than 1 mm size I have to change the "mouth" (I think its correct name should be "chuck") to fit larger tools.
                      • BattleshipBob
                        • 6792
                        • Bob
                        • Cardiff
                        #26
                        That's good Andrea, I thought 1.0 mm was the smallest
                        • Andy the Sheep
                          • Apr 2019
                          • 1864
                          • Andrea
                          #27
                          I forgot to say that chucks of different sizes from my pin vise easily fit into the Tamiya drill.
