Undo Contacta glue?
  • Modler bob
    • May 2022
    • 277
    Undo Contacta glue?
    Hi guys.
    I finally bodged up the Seafire FR47.
    So I bought another on eBay (I'm determined :smiling3
    Anyway, I still want to do the FR47 (wings uo), so gonna have another go ith the new kit.
    I've already Revell contacta glued some of the parts but thought I'd like to build the FR46 (wings down) if possible with the existing kit to save wasting it, and have both to present to my wife.
    Is it possible to unglue some of these bits to rectify it.... ie, the wings?
    hope this makes sense :smiling3:
    Bob
  • stillp
    • 8093
    • Pete
    • Rugby
    Sorry to hear that Bob. I don't think you're likely to succeed, since any solvent that will soften the Contacta will also dissolve the plastic of the kit. Tamiya Extra Thin will soften both.
    Good luck
      • 15696
      A lot of these styrene cements and not really glues. They are plastic solvents. They work by dissolving the styrene in the join, the solvent evaporates and the two parts are welded together. As Pete says you might be able to paint the join with a thin styrene cement and it may wick in a nd allow you to prize the parts apart. Risky. A razor saw may work if the joint is straight.
      • davecov
        • Jul 2014
        • 831
        • Dave
        • Stow, Scottish Borders
        Modler bob Bob, put the parts in a polybag and leave in a freezer for 24/48 hours. Take out and gently prise glued parts apart.
        DaveCov - Founder of The Airfix Tribute Forum 2006
        • adt70hk
          • Sep 2019
          • 10409
          That's a new one!!! Thanks for Sharing Dave!
          • davecov
            • Jul 2014
            • 831
            • Dave
            Thanks Andrew. :thumb2:
            It is not guaranteed to work 100% of the time but it works on other glues as well, such as superglue. A bonus of this method is that you can have an ice-cream when you put it in the freezer and have another one when you take it out.
            • adt70hk
              • Sep 2019
              • 10409
              You sir are a genius!!! :smiling5:
                • 18269
                This has to be tip of the year.
                I can see it working with CA, PVA and other 'glue' like things. However poly cement that melts plastic together... I think the plastic will snap befor the joint does.
                I have had some luck with thin types of liquid poly cement but only on not fully cured joints.
                  • 18903
                  Great tip from Daveโ€˜s old Airfix kit recovery service thereโ€ฆ.
                  Iโ€™ve had glued joints fail spectacularly when using enamel washes. Itโ€™s happened with both Mig and home brewed using oils and white spirit. Itโ€™s why I stopped using them. Wicking in clean enamel thinners or white spirit might therefore help loosen the more stubborn joints that the freezer doesnโ€™t touch.
                    Same, but generally only small parts, like mirrors coming off trucks. I found it depended on which kind of thinner I used, though (in the Netherlands, weโ€™ve got two different things that would both be called white spirit in the UK; it happened every time with one but never with the other).
                    Still, it could be worth a shot to try and loosen a joint. Test the thinner first on the same kitโ€™s sprue, though: let a piece of that soak in it for a few hours to make sure it wonโ€™t just melt it.
                      • 18903
                      My worst example took two whole runs of single link tracks for a German half track right back to component parts Jakko. They had been assembled with Contacta, hence the relevance to the original post.
                      • Modler bob
                        • May 2022
                        • 277
                        I am just looking at my newer seafire FR 46/47 destructions, and I need several more colours for the build, which I think is the original kit.
                        Not a problem as I have the colour chart, and a model shop with most, if not all.
                        But just wondering if Humbrol has brought out their newer Enamel's without the ingredient that scared them across the pond yet? :smiling3:
                        • stillp
                          • 8093
                          • Pete
                          • Rugby
                          I've heard that one before, but it didn't work for me. Worth a try though, if you have room in the freezer.
                          • Modler bob
                            • May 2022
                            • 277
                            Luckily our shopping for the week is tomorrow, so I have put it in a bag in the freezer and will see what happens tomorrow :thumb2:
                            If this works Iaan (Mr Muddle) I'll recommend you for the modeller's award of the year
                              • 18903
                              Just remember it when the time comes, otherwise what will happen tomorrow is it will get squashed by the shopping :tongue-out3:
