Cutting white metal
Tags: None
A small hacksaw. You could use a modeller’s razor saw (that’s not one of those razor blade shapes with teeth cut in!) but that will be more laborious and may blunt the saw faster than you’d like. -
Dremel with a cutting wheel. lowest speed, and no undue pressure - let the cutting wheel cut without trying to hasten the result mate. Slowly, slowly catchee monkey! (Several passes over the same line may be necessary)
SteveComment
Thanks for the suggestions, gents. Because I don't need to keep what I remove, I think I'll try all three methods, back from the true edge, to see which I like.Comment
Me, I’d use a razor saw if it’s a straight cut. One of the larger Xacto types though, not one designed for a knife blade. You could also cut off the excess with a pair of side cutters and clean up afterwards with wet and dry on a hard backing, or use a jeweller’s piercing saw with a fairly coarse blade. Don’t use good files on white metal though. It will clog them up and ruin them.Comment
White metal will clog the saw and make the cut difficult. Score it with a heavy blade or scriber and snap it of. Carefully of course.Comment
You can unclog the saw by dragging the blade sideways along the grain of a scrap of softwood several times. If it is really badly clogged, use a brass wire suede brush rubbed sideways across the teeth first.Comment
