CA glue kept in the fridge?
    • 15698
    Thanks John, that's very useful.
      • 18906
      Having used CA at work for years , in fact since the 70s along with the accelerator I would like to join in .As CA adhesive ages it goes thicker, and produces strings, that's just the nature of the chemical.
      Cyanoacrylate adhesives have a short shelf life. Date-stamped containers help to ensure that the adhesive is still viable. One manufacturer supplies the following information and advice:
      Another manufacturer says that the maximum shelf life of 12 months is obtained for some of their cyanoacrylates if the original containers are stored at 35 to 40 °F (2 to 4 °C).[43] User forums and some manufacturers say that an almost unlimited shelf life is attainable by storing unopened at −4 °F (−20 °C), the typical temperature of a domestic freezer, and allowing the contents to reach room temperature before use.[44] Opening a container while chilled may cause moisture from the air to condense in the container; however, reports from hobbyists suggest that storing cyanoacrylate in a freezer can preserve opened cyanoacrylate indefinitely.
      As cyanoacrylates age, they polymerize, become thicker, and cure more slowly. They can be thinned with a cyanoacrylate of the same chemical composition with lower viscosity.[33] Storing cyanoacrylates below 0 °F (−18 °C) will nearly stop the polymerization process and prevent aging.
      All interesting facts , being truthful about it a fresh bottle is always better , grabs faster doesn't it including Bob's and our fingers .
      Good morning .
      Interesting comment from that manufacturer. If your fridge is running at 13 degC John it’s not doing it’s job and not safe to use
      The pharmaceutical designated temperature for refrigeration is from 2 - 8 degC. Above about 10degC microbial growth can start, allowing food you think fresh to go off without you realising it.
      All of this information seems to be aimed at industrial users who may buy in bulk and store until required for use. Once you open the top it’s all moot, because air returning to the tube after it’s squeezed will contain moisture that accelerates the degradation of the cyano.
      Funnily enough, plastic solvent glues are never mentioned in this context, especially such as Tamiya extra thin. Scientifically they could benefit from refrigeration once opened. The cooler temperatures will minimise solvent evaporation and stop them simply disappearing if the bottle isn’t properly closed. I’m not advocating that either, by the way, I’m just going to try to remember to properly close the bottles :smiling5:
      I must admit I think it a little weird that we try to get a few more pence worth of CA out of a tube, yet keep stashes of kits worth many hundreds of pounds that we may never get around to building. Glue is a consumable…..buy small tubes and buy more frequently, then it’s always fresh :tongue-out3:
      • rtfoe
        • 9086
        #18
        Actually the drier the environment the better and the fridge is ideal for it but in my environment the humidity is so high that its adhesive capabilities deteriorate rapidly once the cap is removed. So always start with a fresh tube. Some manufacturers have found this out and sell mini sized tubes. I keep a bundle of them of different forms...gel, quick setting etc.
        Imagine using CA in the north pole...totally useless if the temperature is the factor.
        Richard aka Wabble
        • BattleshipBob
          • 6792
          • Bob
          • Cardiff
          #19
          Good morning .
          Thanks John, excellent reply and some big words, has your spell checker had a melt down lol
          Learnt a great deal John, much appreciated.
          • AlanG
            • 6296
            #20
            For the amount of CA i use, i only use the small tubes. Far more cost effective in the long run
              • 18906
              Richard aka Wabble
              Fridges aren’t dry environments Richard :smiling5: Commercially, mould is a big issue in fridges, and they thrive in damp environments. We used to have to wipe ours out three times a week with bleach at work to keep the mould counts down…….
              • rtfoe
                • 9086
                #22
                :tears-of-joy: Much drier for us in our kind of climate Tim. But it always defeats the purpose once we take it out of the fridge and reopen the cap...the condensation happens right away.
                Richard aka Wabble
                • The Smythe Meister
                  • Jan 2019
                  • 6248
                  #23
                  Why not just draw a line under this eh guys?!....
                  I think after all the detailed comments,not to mention the "scientific debate", it's just a case of " do what you wanna do"....
                  It's getting tedious now, IT'S JUST A HOBBY.... and,unless there's something I'm missing,we don't really need rocket science?!
                  • KarlW
                    • Jul 2020
                    • 1522
                    #24
                    Rocket science is the easiest science, just saying........ :tongue-out2:
                      • 18906
                      What, like this Roket science?
                      Sorry mate, couldn’t resist it
                        • Jan 2019
                        • 6248
                        #26
                        [ATTACH=CONFIG]n1188386[/ATTACH]
                        That about sums it ALL actually mate
                        • BattleshipBob
                          • 6792
                          • Bob
                          • Cardiff
                          #27
                          Why do my reviews always seem to cause problems??
                          Will stop reviews after the looper, less stress
                          • KarlW
                            • Jul 2020
                            • 1522
                            #28
                            To answer your initial question, yes let it get to room/shed/garage temperature before opening, prevents condensation.
                            • BattleshipBob
                              • 6792
                              • Bob
                              • Cardiff
                              #29
                              Thanks Karl
                                • Jan 2019
                                • 6248
                                #30
                                Don't take offence Bob mate,
                                I certainly didn't mean that!! ...
                                ... It was a perfectly good question in the first place... I just thought that it got a bit over complicated
                                No stress meant to you buddy,I value your thoughts/queries all the time
                                Known you too long to take what you mean any other way than useful
