Micro Milling/Router bits
  • AlanG
    • 6296
    I have been trying to mill/router some holes into some plastic for the last few days, trying various items such as micro drill bits and hypodermic needles. The drill bits are ok but very bendy and fragile. The needles do work but you have to be ultra careful with them.
    Question to the masses is. Are there (affordable) tools out there that can mill/router elongated holes out there that are between 0.3mm and 1.0mm?
  • KarlW
    • Jul 2020
    • 1522
    There are Dremel bits that I've used in the past, but not model related, I'll have to check the size.
    What tool are you using?
    Edit: The bits I have are 2.0mm, but I've just found these.
    • AlanG
      • 6296
      A pin vice at the moment. I need control over the tools as the elongated holes are very small
      Never thought about jeweler engraving tools before. Would these work?
      • KarlW
        • Jul 2020
        • 1522
        A jewellers coping saw might work, feed the blade through a hole and then attach to the handle,
        • AlanG
          • 6296
          I think maybe i might have described what i am trying to incorrectly. The 'hole' i am trying to make does not go all the way through the plastic. I suppose i am trying to scribe/chisel/mill a gouge out of the plastic. I can make a series of 0.3mm holes and try to connect them but the hole looks as rough as a badger's backside.
          I might just have to try and persevere with the drill bit and needle.
          • Gary MacKenzie
            SMF Supporter
            • 1057
            • Gary
            • Forres , Moray , Scotland
            some of the small desktop modeling/engraving routers may have bits that size , but they usually get computer controlled and high speed motors driving them.
            example I am thinking of @ https://www.amazon.co.uk/EsportsMJJ-.../dp/B074QMX34V
            • AlanG
              • 6296
              Think i might have found something that resembles something that i could use.
              Tungsten Steel Panel Line Chisel Set, Holder With 5 Blades 0.2, 0.4, 0.6, 0.8, 1.0mm WZMS-012 MSWZ Scale Model Shop UK, 5* Customer Service, Fast Delivery, Reward points on every order
              Thanks for the advice guys
                • 18895
                If I understand this ( I may not) what you are trying to do is basically cut a groove into a workpiece. If so, something like an acrylic sheet cutter or Olaf P cutter might suit. They were called scrawkers in my day, and you had to make your own, but these days they are available off the shelf…... Tamiya’s panel scriber is just an expensive version of the same tool……..
                They work on the pull stroke, cutting a spiral of plastic out of the groove. They don’t leave a ridge after use like a scriber……
                • Mark1
                  • Apr 2021
                  • 4156
                  Whe ive had to make small holes and had trouble with the drill bit moving around on the surface ive heated a needle with a lighter and just melted the hole i need,this might work for you.
                  • JR
                    • May 2015
                    • 18273
                    Know exactly what your attempting to do , known as a slot cut in woodworking.The only thing I can add is surely the cutter must melt the plastic as high speed is needed , when routing wood the cutter speed is around 18000 rpm depending on the dia of the cutter .
                    • Neil Merryweather
                      • Dec 2018
                      • 5184
                      • London
                      I don't know what the surface is like,or how many you want to do, but have you considered milling out a larger area and then filling up to a piece of 0.3mm styrene the length of the slot? Make the styrene over depth and use a release agent. When the filler is dry remove the styrene and make good the surface .
                      Good luck with whichever method you settle on.
                      N
                      • Mr Bowcat
                        SMF OG
                        • Dec 2016
                        • 4600
                        • Bob
                        • London
                        I found this 1mm cutter, but nothing smaller. https://trenddirectuk.com/trend-2-0x...-diameter.html
                        Si vis pacem, para bellum.
                        • stillp
                          • 8090
                          • Pete
                          • Rugby
                          I found 0.8mm: https://www.amazon.co.uk/SainSmart-N...a-663945169862
                          • stillp
                            • 8090
                            • Pete
                            • Rugby
                            Or these: https://www.amazon.co.uk/dp/B09BCHQ5...9kZXRhaWw&th=1
                            • Gern
                              • 9212
                              Maybe you could cut the slots all the way through then fit a strip of plasticard at the back leaving your groove the right depth?
