Mini files
  • scottie3158
    • 14201
    • Holbeach
    Mini files
    Do any of you fine folk know where I can get some really thin flat files for filling thin slots. I have a selection of needle files but their cross sections are to thick.
  • Mark1
    • Apr 2021
    • 4156
    I dont know if podiatry files would be any good for plastic but come in some pretty small sizes https://www.canonbury.com/instrument...nded-bfde.html
      • 18903
      Not cheap Paul, but clockmakers escapement files might do the job. Failing that, drill and piercing saw are probably the way to go. Last option, use an Olfa P cutter to scribe your way through.
        • 18269
        I have a couple of 'old' Points files from the bygone days of points ignition in ICE motors. They are about 1 maybe 1.5mm thick, stiff and sharp- only negativ is they are 1cm wide!
        These might be of more use to you. also AlanG who has a comparable problem with cutting slots.
        • Neil Merryweather
          • Dec 2018
          • 5188
          • London
          I use a metal nail file which is about 0.75mm thick,and I have one that I ground down to about 3mm wide. Worth having a look in superdrug?
          • Neil Merryweather
            • Dec 2018
            • 5188
            • London
            Or double sided tape some wet and dry to a small piece of PE brass?
            • scottie3158
              • 14201
              • Holbeach
              Thanks guys, some excellent ideas. Many thanks for the suggestions I will have a look.
              • Scratchbuilder
                • Jul 2022
                • 2689
                scottie,
                I use various grades of wet n dry attached to either thin metal sheet cut to size or plasticard with double sided tape to get into the crevices others cannot reach. Obviously you will not be putting too much preasure on the sanding so this might help.
                Mike.
                • Mr Bowcat
                  SMF OG
                  • Dec 2016
                  • 4600
                  • Bob
                  • London
                  Paul, Ultimate Modelling Products do customisable cut to shape sanding pads, they are about a mil thick.
                  Si vis pacem, para bellum.
                  • AlanG
                    • 6296
                    I know they are Tamiya but they aren't light on the wallet are they!
                    • scottie3158
                      • 14201
                      • Holbeach
                      Thanks all for the great feedback some food for thought.
                      • stillp
                        • 8093
                        • Pete
                        • Rugby
                        Engraving to emphasize details such as panel lines, or even add custom detail is a popular advanced modeling method. Tamiya makes this advanced modeling technique easy with its line-up of engraving blades. These fine engraving blades are made from tungsten carbide, and offer a smooth, consistent finish. They are available in a choice of various thicknesses to meet your modeling needs. • 0.25mm Fine Engraving Blade x1• Total length: 25mm. Shank diameter: 2mm.• Recommended for use with dedicated holder Item 74139 Engraving Blade Holder. Also compatible with Fine Pin Vise D (Item 74050) and D-R (Item 74112).• Simply hold at a 45- to 60-degree angle and pull lightly across the surface to score it. Repeat as necessary to achieve a clearly-defined result.• Comes in a case that can hold up to ten blades.• A color-coded marking on the shank allows easy identification of blade thickness.
                        • scottie3158
                          • 14201
                          • Holbeach
                          Peter,
                          I saw these and they do look good but a bit rich for my pocket.
