What's on the Bench 2023
  • Waspie
    • Mar 2023
    • 3488
    #166
    Originally posted by Waspie
    I may try and run this past SWIMBO. I'm not going to hold my breath but I know she'll be at her weakest tomorrow as it's her birthday and she hates reminding she's older!!!!! So strike whilst she's not at her best. I have a desk that my PS sits on and little else other than the monitor!!! If I can fit the PS on the floor or inside the cabinet!!! Wish me luck!!!
    Well it was a fail with a but!!!! I did negotiate moving some of the 'stuff' (Garden swing and summer paraphernalia out of the man cave). That alone gives me more room to tinker!!! (If the new arrival allows)Click image for larger version
    • Mini Me
      • Jun 2018
      • 10711
      #167
      I decided to make a different fuel truck for use with the upcoming Dio ........started with this, it needs a lot of improving to suit my needs so I'll start a build thread on it.Click image for larger version
        Originally posted by Andy T
        What's on the bench?
        How about a new (temporary) bench?
        Some of you may have seen me rumbling about working out in the shed so as a temporary measure I've rearranged my PC desk to give myself a little painting area for figures and small stuff. Should give me something to do when I don't fancy going outside and it all packs away into a small box to keep her indoors happy.
        If it works out okay I may set up something more permanent in the other room, with space for extra paints etc.
        Maybe even a build section. Baby steps :smiling3:
        [ATTACH=CONFIG]n1198027[/ATTACH]
        "One small step "
          • 18272
          Popped my Churchill cherry! AFV Club mkIII.
          AND a set of track links....pain in the butt they are too.
          Coffee break.
          • adt70hk
            • Sep 2019
            • 10435
            #170
            [ATTACH=CONFIG]n1198663[/ATTACH]
            Coffee break.
            Would be interested in an SBS... Have a set on order!
            • The Smythe Meister
              • Jan 2019
              • 6248
              #171
              Coffee break.
              Looking good...
              ... I've not built a Churchill yet either!
              That looks to be a well detailed kit.
                • 18272
                What the tracks? The tricky bit of the tank build is done,
                • adt70hk
                  • Sep 2019
                  • 10435
                  #173
                  Yes....the tracks. Just curious.
                  • Waspie
                    • Mar 2023
                    • 3488
                    #174
                    Errr, SBS?
                      Here you go. I found them pretty painless to assemble, as far as workable tracks go โ€” the parts are pretty easy to clean up, they fit together well, and thereโ€™s only two pieces to a link
                      It is, but it takes some work to put together. Not that thereโ€™s bad fit, but itโ€™s an AFV Club kit, which are never shake-the-box type deals. Think small parts, fragile parts, many of them, sometimes tight fit, large ejector pin nodules to remove, instructions that arenโ€™t always perfectly clear where parts are to go, and similar small things like that.
                      • Si Benson
                        • 3572
                        #176
                        Errr, SBS?
                        Step By Step
                        • Waspie
                          • Mar 2023
                          • 3488
                          #177
                          Originally posted by Si Benson
                          Step By Step
                          Thanks Si, I somehow guessed it wasn't the quiet killers from below the sea!!!
                          • Andy T
                            • Apr 2021
                            • 3239
                            #178
                            Trying my hand at a 28mm miniature. How some of you get such great results at this scale is beyond me :surprised:
                            Still loads to do but I'm enjoying the process and the steep learning curve, and pleased with what I've done so far given my inexperience.
                            Besides, if I'm not happy at the end I can just dump it in the meths tub then give it my son to paint properly :smiling5:
Name:	2023-04-14 18.11.21.jpg
                            • Nicko
                              • Apr 2019
                              • 1425
                              • Nick
                              • East Anglia
                              #179
                              Looking good so far though Andy..
                              Nick
                              • Andy T
                                • Apr 2021
                                • 3239
                                #180
                                Thanks Nick.
                                The hardest bit is not stuffing up what I've already done with a wayward brush stroke :smiling5:
