What's on the Bench 2023
  • Scratchbuilder
    • Jul 2022
    • 2689
    #331
    Originally posted by Jakko
    That photo of the submarines has me wondering why the cutting mat has the grid lines numbered both very big and fairly small :smiling3:
    Jakko, that's easy.... One is for bigmillimeters and the other is for minimillimeters :tears-of-joy:
    • Scratchbuilder
      • Jul 2022
      • 2689
      #332
      Here you go JR, just for you....
      Main bench....
      Bench #2 which sits to one side....
      And finally tool area....
      And as you can see, not a lot of space left for modelling....
      • JR
        • May 2015
        • 18273
        #333
        Main bench....
        [ATTACH=CONFIG]n1205243[/ATTACH]
        [ATTACH=CONFIG]n1205244[/ATTACH]
        [ATTACH=CONFIG]n1205245[/ATTACH]
        But you have 2 benches Wibble, that's living it large . Apparently modern parlance, that's from something I heard one of our grandson saying .
        Wobble
          • 18932
          Interesting selection of uncommon scalpel blade shapes there. Never seen anyone use those wide oblique angled ones before. Care to enlighten us on their modelling uses?
          • Mini Me
            • Jun 2018
            • 10711
            #335
            Here you go JR......just found this in the photo archive. Three little Opels all at once.Click image for larger version
              • 18271
              Could have been a coating over the chrome that the brake fluid removed, then the bleach was able to do its job. Anyway, it’s gone :thumb2:
              After 6 or so hours In a bag with oven cleaner absolutely no change!
              I have rinsed if off and it is now in a bag of cola!
                • 18932
                Er, cola is a dilute phosphoric acid solution with sugar and caramel. Can’t see it doing much to be honest….be chuffed for you to prove me wrong though.
                • JR
                  • May 2015
                  • 18273
                  #338
                  Originally posted by Mini Me
                  Here you go JR......just found this in the photo archive. Three little Opels all at once.[ATTACH=CONFIG]n1205257[/ATTACH]
                  Very nice Rick . See the metal base you work on .
                  • Scratchbuilder
                    • Jul 2022
                    • 2689
                    #339
                    Tim, no problem.
                    From left to right.
                    The long scalpel with #10A blade is for applying c/a along edges, for example a 90 degree corner.
                    The next three are #9 blades with the centre one having being re shaped for cutting etch brass from the fret. The other two are for the same but resin and plastic.
                    The next is a #10A used for general cutting of plasticard.
                    The Stanley is the workhorse and is used for most work with plasticard, there is a thin white strip next to the blade where is goes into the handle, this is a thin piece of plasticard that is there to stop the blade from moving when cutting.
                    And finally on the bench there is another scalpel with a #10A blade and that is re-cycled and sanded to a point to pick up the rivets - dip them into c/a and then position them onto the model - or any other small item.
                    Mike
                    • Scratchbuilder
                      • Jul 2022
                      • 2689
                      #340
                      Wobble
                      But Wobble, I do like things in sterio, truth be told the whole room is a work bench of some kind, if it's horizontal it's a bench.... Now as for the shed.....
                      Wibble
                        • 18932
                        Tim, no problem.
                        From left to right.
                        Mike
                        Cheers Mike
                        Always interested in how others do things. I lucked into a decent number of handles when health and safety removed scalpels from our workplace…..safe knives are nowhere near as useful for modelling…..
                        I find retractaway handles great for protecting the edge on the best use scalpels as well.
                        I use 10a for straight cuts in plasticard as well. Never used one for applying CA though, just use a scrap of wire. Might try that Got an x-acto curved blade with the edge smoothed off with wet and dry to apply filler though.
                        Only use a Stanley for heavy duty cuts myself. Got a couple of other heavier straight scalpel blades (number 25 I think) on a 3 handle for that job.
                        Never used a 9 blade. Tend to use a big curved blade (21?) on a number 4 handle for that job. Might try that one as well.
                        My most used is a number 15 on a three handle for scraping part seams. The curved edge doesn’t leave scratch marks on the workpiece.
                        Seems like there are almost an infinite number of scalpel shapes doesn’t it
                        • Scratchbuilder
                          • Jul 2022
                          • 2689
                          #342
                          Cheers Mike
                          And not just for cutting up bodies...... :tongue-out3:
                          • rickoshea52
                            • Dec 2011
                            • 4076
                            • Rick
                            #343
                            This is on the bench following the T-55 getting finished.
                            [ATTACH=CONFIG]n1205242[/ATTACH]
                            In progress…with lights!
ID:	1205631Click image for larger version
                            • rickoshea52
                              • Dec 2011
                              • 4076
                              • Rick
                              #344
ID:	1205870Click image for larger version
                              Lights all connected and still working, not bad for a club fisted rigger.
                                • 18932
                                Looking good Rick. The head on shot looks like she’s smiling in approval as well.
