The tidy up !
  • JR
    • May 2015
    • 18273
    The tidy up !
    Not one for being tidy when working , I prefer to clean up at the end of a job, it was the same at work .
    Today a start was made, I did my usual fall asleep after lunch , but late pm a start was made .Tomorrow Christine is planning to take charge and clean the other side where the completed builds are kept .
    Not found any modeling bits yet, but did find a pack of files !
    Bench cleaned .Below the top cover has been removed, only use this when cutting foam board and measuring.
    Tidied up the tool rack , and left hand side of bench.
    Tomorrow as said , the other side under instruction from the Boss .
  • Allen Dewire
    • 4741
    • Allen
    • Bamberg
    OMG!!!......PM in the morn Brother...............
      • 15669
      Still a way to go but a good start. :smiling: :thumb2::hugging-face:
      • JR
        • May 2015
        • 18273
        Yes indeed, Matron is on standby to help if needed .look fwd to the mail :thumb2:
        Why thank you Sir, a long way from your high standard, but tomorrow with being under instruction from Christine I can guarantee a much higher finish .:nerd:
        Just notice the right hand open shelf is in need of a tidy , the wire and cable container is over flowing !.
          • 18892
          Going well John, but are you sure you have enough pliers there? You’ve even got some that look a bit like fencing pliers……
          • JR
            • May 2015
            • 18273
            Hi Tim, ha , yes bought some , then do as you do needed a different jaw which was smooth. There's a good mix of tools, some should be in the other tool shed but some how have found their way in here .
              Should have taken a “before” picture as well, really
              Also, what is that strange hammer-cutter-thing?
              • outrunner
                • Apr 2019
                • 2420
                Originally posted by Jakko
                Should have taken a “before” picture as well, really :smiling3:
                It's a wood hammer multi tool, bit like a giant Leatherman but with a hammer.
                Andy.
                  When I was working, my desk(s) were always covered with drawings, engine components, verniers, magnifying glasses etc. The engineering director used to moan & bitch about it being messy.
                  " Tidy desk, tidy mind " he used to say. at first I just ignored him, but he said it virtually every time he came into my office. Finally I had enough & started to reply " empty desk, empty mind ". He never appreciated this ( He's been production manager before being promoted ), he wasn't used to independent thinkers, and a design department is full of independent thinkers
                  • stona
                    • Jul 2008
                    • 9889
                    It raises an interesting question!
                    John's workspace looks fabulous now that he's tidied up but what kind of a shambles do we normally work in?
                    I tend to keep things reasonably tidy as I go along, but that's because if I don't I start losing things, sticking things to my chair, the neighbour's cat etc.
                    This is my workspace as it was about five minutes ago. I promise that I just stuck my head in and took a snap, no prior tidying up. It's as I left it when I came in for lunch.
                    Who else dares?
                    Edit: The light machine oil is nothing to do with model making, it's for the bass drum pedal just barely visible behind the compressor. Squeaky pedal = bad!
                    • wotan
                      • May 2018
                      • 1150
                      John and Steve you are both sick people, I would post my workspace only I can't find my camera,
                      • minitnkr
                        Charter Rabble member
                        • 7520
                        • Dayton, OH USA
                        A place for everything & everything in its' place.
                        • Neil Merryweather
                          • Dec 2018
                          • 5184
                          • London
                          Oh alright then;
                          50/50 tidy/untidy
                          Construction side
                          Painting side (180 degrees)
                          • boatman
                            • Nov 2018
                            • 14451
                            • christopher
                            • NORFOLK UK
                            WELLL THIS is my work bench after jens had a tidy up an now i cant find any thing Aaaaaaccchhhhh
                            chrisb Click image for larger version
                              • 18892
                              chrisb [ATTACH=CONFIG]n1192113[/ATTACH]
                              That’s AFTER the tidy up……Ay Caramba……..
