Neil's 1-32 scale 3D printed Flamethrower
  • Neil Merryweather
    • Dec 2018
    • 5204
    • London
    I first posted this in What's On The Bench, but I think it might expand a bit, so here's a full thread.
    I got a bit 'Fusiliered Out' so I started building this digitally for a diorama I'm planning, using up my stash of Airfix Multipose US Marines.
    Of course nobody does any accessories in 1-32 scale now ,so I measured a 1-35 offering by Dragon, and scaled up to full size, then I re-scaled to 1-32.
    Here's a WIP screen shot -the different colours are all the separate elements which are individually editable until I combine them together and 'fix' them once I am happy
Name:	M2 Flamethrower.jpeg
    It took me a few days but here's the final piece
Name:	finished M2 Flamethrower.jpeg
Name:	finished M2 Flamethrower 2.jpeg
    The carrying frame is very thin so I have made 3 versions in different thicknesses as a safety net.
    Here's a pic showing how I've separated the various components for printing
Name:	finished M2 Flamethrower 3.jpeg
    There should be a canvas panel suspended between the verticals of the carrying frame, but I will fabricate that, along with the flexible hose.
    So fingers crossed I will be printing this tonight
    FYI it's 22mm tall
    • 15784
    This 3D printing is beyond me but I can see it's potential. It's very interesting and I look forward to seeing the printing itself.
    • Mickc1440
      • 4786
      A serious dark art
      • Neil Merryweather
        • Dec 2018
        • 5204
        • London
        I've set up the printer (resin, Elegoo Mars 2 ,for those who care about these things) and this is what it looks like virtually
Name:	Elegoo Mars Build Plate.jpg
        I'm also printing some packboards and Marine style boot soles as most of them will be lying down(can you guess where I'm going with this?)
        So here goes, we'll see how well it turns out in the morning
        • AlanG
          • 6296
          As said by others. Dark arts. I seriously wish i could use the programs. I have so much i would like to design that isn't catered for in 1:32
          • Allen Dewire
            • 4741
            • Allen
            • Bamberg
            WOW!!!...Can't say more than that Neil. It looks incredible and I do hope it prints out well for you...
            Allen
            • adt70hk
              • Sep 2019
              • 10436
              Mind-blowing..... And I'm quite technically minded!!
                Yet another advantage of the resin printer - you can pack as many models onto the build plate as possible, and it will take the same time as if there were only one. If I put two objects on my FDM printer, that doubles the print time.......................
                • Neil Merryweather
                  • Dec 2018
                  • 5204
                  • London
                  You're so right Dave. This is a 6 hour plus build because I set the layers so thin (0.02mm) for better resolution. I've also done a couple of duplicate parts with different orientations to see which works better support-wise.
                  I've had the printer a year and it's already been superseded twice. My screen is 2k, (which indicates the pixel size I think-it defines the resolution anyway) and there have since been 4k and now 8k screens. For big stuff it doesn't really make much difference, but for small detailed stuff like we do it really does. My son has an 8k printer so I will get him to print this and we can compare results
                  • AlanG
                    • 6296
                    I was going to go down the 8k printer route as the stuff i want(ed) to print has to be detailed. I think i might have to go onto YT and have a look again at what programs to start off with. And then try and get some designing done
                    • Neil Merryweather
                      • Dec 2018
                      • 5204
                      • London
                      Well, it printed- some of it great, some not so great and I don't really know why.
Name:	Build Plate.jpg
                      The tanks developed a 'middle-age spread' for some reason
Name:	Tank Components.jpg
                      but I'm pleased with the finer details.
                      The different sized frames are difficult to tell apart, so I can use the thinnest one (second from right) - if it survives the support removal. The particular resin I've got is very brittle and snipping the support can sometimes fracture the piece itself. There are more flexible and forgiving resins around which I shall pay more attention to when I next buy some.
                      I built the gun in two different orientations to see which came out best, and (using the optivisor) it's the angled one that's marginally better, although neither of them is terribly sharp....
                      By far the worst build was the packboards
                      I don't understand why they have the extra material attached to them- perhaps the support was too flimsy and they wobbled about during the build. That said , I used the same orientation when I printed them before at 1-35 and they came out fine, which is why I did it this way this time. Hmmm
                      I can probably use them as long as they are fully loaded, but it's irritating to have it happen, and I need to know how to avoid it.
                      Far and away the best prints are the boot soles
Name:	Boot Soles.jpg
                      there ARE more and they do make up pairs!
                      So that's where we are ,I'm going to get my son to run them on his 8K printer and we'll see how they compare.
                      • AlanG
                        • 6296
                        I precede 3D printing so i have no excuse other than booze for my middle-age spread :smiling3:
                          • 15784
                          A mixed bag of results Neil. I'm sure you'll find solutions to the issues. Still looks good to me.
                          • Richard48
                            • 1910
                            • Richard
                            • Clacton on Sea
                            Looks great Neil.I wish somebody would 3d some of the U.K afv/tank aerial mounts for Shermans etc in 1.72nd.The photo etch ones are just ludicrous to put together.
                            Great stuff mate.
                            Rich
                            • Gary MacKenzie
                              SMF Supporter
                              • 1059
                              • Gary
                              • Forres , Moray , Scotland
                              Beware of the 8K , as that is 8K spread across the print bed , and some 8K have lower dot resolution per inch than others.
                              an example from the same company
