Neil's 1-32 scale 3D printed Flamethrower
  • Neil Merryweather
    • Dec 2018
    • 5204
    • London
    #31
    Second attempt crashed & burned yesterday, except for the tanks, which is just as well because they got worse on the third attempt, even though everything else was improved-even the vertically oriented packboard, which WAS a surprise.
Name:	third attempt.jpg
Name:	third attempt b.jpg
    So I do have a usable full set, and a reserve of slightly lesser quality if I cock it up.
      • 15785
      Certainly looks good although I appreciate there are issues. It definitely shows the potential. I suppose the process is still in it's infancy for the hobbist at home. Are the printers which commercial 3D printers use vastly different and more expensive that those used for home printing?
      • The Smythe Meister
        • Jan 2019
        • 6248
        #33
        Fascinating to watch Neil...
        .... Love those Tanks, very nice imho
        • Neil Merryweather
          • Dec 2018
          • 5204
          • London
          #34
          Cheers Jim,
          Yes is the answer,by at least 20 times for a basic one
            Neil,
            are those tanks solid? I've read of needing holes to drain resin from parts - or is there a size when this is needed?
            • scottie3158
              • 14242
              • Holbeach
              #36
              Neil,
              Nice work mate. This is all to complicated for me but I like the results you achieve and the problem solving involved.
              • adt70hk
                • Sep 2019
                • 10436
                #37
                Ooh I would have so much fun with that Neil !
                Now there's a shocker!!!
                • Gary MacKenzie
                  SMF Supporter
                  • 1059
                  • Gary
                  • Forres , Moray , Scotland
                  #38
                  Neil,
                  Resin: Anything hollow needs drain points ( unless it is a tube so open both ends, whereas anything solid shouldn't as there should not be any uncured resin inside.
                  • Gary MacKenzie
                    SMF Supporter
                    • 1059
                    • Gary
                    #39
                    Neil , granny and suck eggs question, what temp is the resin at in the tank, as cold resin = higher chance of failure ?
                    • Neil Merryweather
                      • Dec 2018
                      • 5204
                      • London
                      #40
                      It's a bit lower than Room temp but not much
                      • Neil Merryweather
                        • Dec 2018
                        • 5204
                        • London
                        #41
                        Neil,
                        Yes you would need drain holes if they were hollow but they are solid. There's no technical need to make things hollow other than weight and cost of resin. With this kind of process it wouldn't affect the build time
                          All very black art to me, but enjoyable to learn and read Neil.
                          • Waspie
                            • Mar 2023
                            • 3488
                            #43
                            Is there anything that can't be 3D modelled?
                            3D rocket into space!
                              One thing that I haven't seen is the ability to print clear objects - specifically cockpit canopies, although I bet someone, somewhere is trying!
                              • Waspie
                                • Mar 2023
                                • 3488
                                #45
                                AN article I have just read does say clear is possible! Article. So someone must be trying or even succeeding!!
