Eduard removable cover film decals
  • adt70hk
    • Sep 2019
    • 10402
    #16
    They look very good indeed Tim. I'll have to have a look to see which of mine will have these type. I assume it's likely to be new releases.
      • 18894
      Originally posted by Jim R
      Thanks Tim. Look very effective.
      No probs Jim, glad I could be the Guinea pig….
        • 18894
        Originally posted by colin m
        My dull brain cells seem to remember Eduard claimed this wasn't actually a feature of their decals. Maybe just a happy accident.
        I believe it’s a side effect of them being digitally printed, but it certainly improves their effectiveness Colin.
          • 18894
          They do don’t they :thumb2:
          Apparently it’s any decals printed after 2020 Andrew.
          • adt70hk
            • Sep 2019
            • 10402
            #20
            Thx Tim!
              After stripping them all, I had a couple of minor failures.
              One stencil came off completely, so obviously hadn’t been put on properly. The other issue was an overlap on the tail transfers and was my fault. Like a numpty I didn’t take into account that overlapping decals won’t strip cleanly….the overlying decal gets damaged in the process. It’s nothing too extreme, just looks like a little chipping of the paint…..
              Over all, I’d say that even without stripping they are as good as any decals I’ve ever used. The carrier film is very thin so could be left alone with no real issues, but in certain circumstances , such as bare metal finishes, I would say they are difficult to beat.
              controversy over! The issues you had have probably been shared by many.
                Aside from year (some older kits have been reboxed) how does one know if they are the ‘transfer’ type?
                  • 18894
                  I’m sorry, that I don’t know…..should be the case for any kit produced since 2020 though. I suppose you could always test a decal from the kit that you are not going to use…..
                    • 18266
                    I bet stencil decals look really good with this type.
                      What’s weird is there are no instructions or any indication if you have the ‘new type’ or not. So here goes;
                      Tim is right to say post 2020 for decals - bear in mind though that it seems if Eduard has reboxed a kit (like my build) where the original box was pre 2020 then the decals are new type.
                      They are pretty awesome. I was worried about trying as I used my microsol and didn’t want to pull up my efforts!
                      So I took the plunge and hey presto! Just need a blade to lift up corner and then treezers to peel off slowly. Try to get all film in one peel but no dramas if not. Actually once you strip off a bit then the rest follows easily - you might just have to prompt a bit with blade again.
                      [ATTACH=CONFIG]n[/ATTACH]
                        • 18894
                        That’s exactly what I found. I believe the lack of instructions are because this is not a design feature, just a by product of their current digital production technique.
