Where do you have your instructions?
  • Andy T
    • Apr 2021
    • 3239
    Strange question I know but I'm looking for ideas. Where do you have your instructions whilst building?
    I normally work like this (and I don't just mean in a mess lol) with them on the bench, building on top. It helps me when there are a lot of similar parts as I can lay them out in place, but obviously it's a pain when I need to flick back & forth, and more importantly the glare from my overhead lamp can be tiring on the eyes.
    I've tried propping them up at the back of the bench but I can't see them properly without swapping glasses all the time, and if I stand them in front of my drawers I'm even less likely to put tools away after I've finished with them so the desk soon gets swamped.
  • JR
    • May 2015
    • 18273
    Always a problem Andy, I have a gap at the side of the raised build area , it end up in there with things on top of it . Think one of those cooks recipes stands is what we need.
      • 15679
      I have the sprues and the instructions on the bench to the left of the cutting mat I work on. As parts get taken off the sprue, cleaned up and assembled they go on the bench to the right of the cutting mat.
      I write on the instructions. I use coloured high lighters to show parts removed, stages completed, things to watch out for etc.
      • BattleshipBob
        • 6792
        • Bob
        • Cardiff
        I have a cheap cork board on the wall, I pin the required page into it and same as Jim I am starting to highlight areas for pe etc
        • JR
          • May 2015
          • 18273
          Jim and Bob.
          I do the yellow marker high lighter as I go , write things to do later , those bit you know will get knocked off . Will find some way now of houlding the instructions so they don't get buried.
          • Andy T
            • Apr 2021
            • 3239
            Thank you so far. The more ideas the merrier and I might find something that works better than what I have now.
            I'd thought about a music stand John. I'm sure Zoë still has one from her brass band days (French & Tenor horns) although I'd lose the desk space behind it.
            And yes, highlighting and general scribbling comes in handy for me too.
            • Nicko
              • Apr 2019
              • 1402
              • Nick
              • East Anglia
              When I created my little work area, I fixed a magnetic white board to the wall right in front of the bench with the intention of sticking the instructions to it. However, I soon found I spend so much time flipping back and forth that I don't use it for that. I tend to just keep them on the windowsill next to me....
              The board is still handy for scribbling on though.
              Nick
              • JR
                • May 2015
                • 18273
                That sort of thing Andy. The only thing not to far away so you can't read it clearly .
                • rickoshea52
                  • Dec 2011
                  • 4076
                  • Rick
                  Instructions are for wimps!
                  • Airborne01
                    • Mar 2021
                    • 3964
                    • Steve
                    • Essex
                    An upright magnetic knitting plan holder to the right of the work area, hold instructions with small magnetic clips and use pencil to strike through removed parts or circle parts yet to be attached.
                    • rtfoe
                      • 9074
                      I have a shelf above the table and suspend two clips to hold the intended page of the instruction open. Now I basically study the instructions beforehand and cut out all the parts needed for that step of build, dry fit and seldom refer to it again until the next step.
                      Wabble
                        • 18266
                        I normally put them wherever there is room. lol
                        As a bifocal user I have issues with how far away they are and if I can look right at them just by turning my neck. I have found an app for smartphones and pads that you can make a pdf by photographing the subjects then string them together, I might one day try that on my tablet... Hmm
                          • 18901
                          I keep mine on the right of the work area, being right handed. They are within easy reach and can be picked up and put down as required. I also keep a pen there and scrawl my own instructions and build tips all over them. When I got back into the hobby I did think about buying a copy holder (like secretaries use for transcription when typing on PCs)
                          but never got around to it. I’m so used to working this way that I probably never will now.
                          Copy holders are like this…..not cheap these days though.
                          • Neil Merryweather
                            • Dec 2018
                            • 5184
                            • London
                            Yep I have one of those. No idea where I got it from, I certainly wouldn't have spent money on it -possibly being thrown out at work - ah yes I remember, it was broken so I rescued it and repaired it .
                            Very useful for reference images as I don't build many kits
                            • Andy T
                              • Apr 2021
                              • 3239
                              Copy holder - that's the kind of thing I had in my head but didn't know they existed! Pull it closer to study then move it away if I need more space.
                              Looks like the kind of thing I could knock up from a spare Ikea anglepoise lamp and a piece of board...
