Gluing static grass
  • Si Benson
    • 3572
    Gluing static grass
    Wondering what glue you guys are using/would recommend when using static grass?
  • scottie3158
    • 14201
    • Holbeach
    Si
    I use diluted PVA with a few drops of washing up liquid in it to help it flow on the base. This can be brushed or applied via a dropper.
    • The Smythe Meister
      • Jan 2019
      • 6248
      Tried different methods for years mate...
      Never cracked it really,I'll be looking out for any tips or methods that you'll think of/receive
      • Andy T
        • Apr 2021
        • 3239
        If I'm using a static applicator I'll apply neat pva to the surface then sprinkle the grass on top, usually working in random patches rather than a full spread over the whole area, to give a "tufty" look rather than a perfect bowling green.
        • Lee Drennen
          • 7711
          I paint the base with a earth color then apply it that way you can get a underneath dirt look. When the paint dries the grass should stay. Here’s a example Click image for larger version
ID:	1210599Click image for larger version
ID:	1210600Click image for larger version
ID:	1210601Click image for larger version
          • Si Benson
            • 3572
            Si
            I would never of thought to use Squishy up liquid with it or to thin it Down. I’ll definitely have to try that :thumb2:
            Do you have a PVA of choice?
            • Si Benson
              • 3572
              Never cracked it really,I'll be looking out for any tips or methods that you'll think of/receive :smiling3:
              I remember your Jagdpanther (?) with the blown track ( I hope that’s right) and the torn up grass…..looked good if indeed it was your/s and I’m not just loosing my marbles :smiling5:
              My attempts are never really convincing. I built myself an applicator thingy and Everything. :thinking:
              • Si Benson
                • 3572
                This is a good point, maybe I shouldn’t look at my lawn for inspiration!
                • Si Benson
                  • 3572
                  I paint the base with a earth color then apply it that way you can get a underneath dirt look. When the paint dries the grass should stay. Here’s a example [ATTACH]492722[/ATTACH][ATTACH]492723[/ATTACH][ATTACH]492724[/ATTACH][ATTACH]492725[/ATTACH]
                  Beautiful layout Lee, my teenage son is pestering me to put a double O layout in the attic (not sure of scale compared to US scales ?) and I’m trying to convince him to go N gauge and have in his room instead…..hoping I can get his agreement as it will be less jobs for me
                  So are you saying zero glue….just paint to retain it?
                    • Jan 2019
                    • 6248
                    Blimey mate, you've got a good memory!!
                    Yes, indeed that was my wrecked Jagdpanther,way back then!:hugging-face:
                    It's still one of my favourite builds if I'm honest,thank you for remembering it!:thumb2:
                      • 18903
                      Dilute PVA here as well. If you are using an applicator don’t forget to put one pole in the glued area so the charge can build up….I usually push a pin into the surface and use a crocodile clip on the wire to attach it.
                      • JR
                        • May 2015
                        • 18273
                        Si, have a look at Luke Towan on UTube.
                        Here he discusses the use of both the PVA and the washing up liquid being added .
                        • Si Benson
                          • 3572
                          Be good to see it again :smiling4:
                          • Si Benson
                            • 3572
                            My logic was that thicker glue would hold the grass better, but it seems diluted is the way to go.
                            • Si Benson
                              • 3572
                              Evening mate, hope all is well at Race towers?
                              Now this is an extremely handy result as I actually have a pot of modge podge at the back of the cupboard for ages!
                              Thanks very much for finding that video:thumb2:
