Wet sanding and what's best to use?
  • BattleshipBob
    • 6792
    • Bob
    • Cardiff
    Afternoon
    Advice if possible please
    Been using wet sanding for the first time on the Fletcher. Used one of my favourite sticks, Albion sanding sticks, nice and thin. However using them wet is of course bringing the backing off so they are falling apart.
    Can anybody advise as to what they use, I do have suitable sanding sheets but it will be awkward to get into places that the Albion can get into?
    Ta bob
    • 15679
    I have only used wet sanding on resin to keep the dust at bay. I use very fine wet & dry paper. I shape coffee stirrers into different shapes and then use waterproof wood glue to stick on the wet & dry paper. They work ok and are cheap enough to replace when worn or the wood goes soggy and out of shape.
    • simontie
      • Jan 2010
      • 1506
      I use lolly pop sticks and an assortment of graded paperu pva’ed to them, press them down over night voila cut them to what ever size suits.
      (i paste the whole sheet and lay the sicks out on them)
      simon.
      Why is common sense not so common?
        • 18266
        Off to Halfords, or what they are called these days, buy a sheet of each wet and dry in all the fine sizes. 4000 as the most course and right up to 12000!
        • BattleshipBob
          • 6792
          • Bob
          • Cardiff
          Thanks both, that's one thing I have changed is too use a less aggressive grit!
          • simontie
            • Jan 2010
            • 1506
            Screwfix or tool station can have some good deals on papers
            • BattleshipBob
              • 6792
              • Bob
              • Cardiff
              Thankfully when I worked at the college the body shop donated a large amount of the stuff !
                • 18901
                Wet and dry for me as well Bob. It’s exactly what it was made for. Remember to clean the surface between grades though, otherwise the slurry left behind is still sanding like the rougher stuff when you go to a finer paper.
                  • 15679
                  Never thought of that
                  • BattleshipBob
                    • 6792
                    • Bob
                    • Cardiff
                    simon.
                    That's a cracking idea Jim, ta very much. Need to make thin ones to use like the original Albion ones. Must start nicking coffee stirrers lol
                      • 18901
                      Double sided tape on plasticard works as well Bob……
