Realistic Bullet Hole/Shell Damage Question
  • malvern_man
    • Sep 2023
    • 80
    • Chris
    • Derbyshire
    Hi all,
    The Warhammer Leman Russ tank that I am currently building has an optional bulldozer blade which I am going to use. I have created some bullet holes/shell damage on the face of the blade ( see attached photo ) The blade isn't finished yet as it needs weathering and chipping etc.
    I've filled the holes with a bit of Vallejo silver and I was just going to just drop a bit of Vallejo black wash into each hole but is there anything else I can do to make them look a bit more realistic.
    Regards, Chris.
    Those look pretty good. I would paint the areas around the bullet holes with a metallic colour as well, to represent the paint having chipped off there, though.
    • malvern_man
      • Sep 2023
      • 80
      • Chris
      • Derbyshire
      Thanks for the reply, do you mean paint inside the bits that I 'dug out/scored' with my scalpel?
      Regards, Chris.
      • Andy the Sheep
        • Apr 2019
        • 1864
        • Andrea
        • North Eastern Italy
        You can also try with some graphite to blacken the hole surroundings. I had good results also using black powder from old firecrackers (and if you want to take a walk on the wild Race side, you can fill the hole with a SMALL amount of black powder and then ignite it to give a more realistic aspect, but this is a rather wild way to reproduce the marks left by a shell impact:face-with-head-bandage::rolling
          Certainly inside the scored bits, as the paint obviously wouldn’t be covering the metal anymore there. Perhaps also a bit around them, but not everywhere, to represent more paint flaking off due to the impact.
          • Andy the Sheep
            • Apr 2019
            • 1864
            • Andrea
            An example of a firecracker used to simulate a shell impact. It's the burned area on the turret number.
            It's a Tamiya 1:35 Panther I built in the '70s... thus the aged look of the model.
