Airbrush spray booth
  • BarryW
    • Jul 2011
    • 6010
    #16
    By contrast, this is the one I use also on the Benchvent site
    The BenchVent BV300S-D extracts fumes & vapours from aerosol paints and lacquers, including solvent based materials. Buy Direct Today!
    • Andy T
      • Apr 2021
      • 3239
      #17
      I always thought the two were the same apart from the extraction or recirculation part but the data sheets say different.
      The 'S runs an axial fan whereas the 'S-D has a centrifugal one, presumably to counteract the extra back pressure of the hose, where "squirrel cages" have the edge.
        • 15669
        Interesting that the BV300S has a photo with Premi Air Liquid Reamer in it. That's a pretty smelly solvent, shifts most paints.
          • 18892
          Thanks for that Barry. Useful to see the specifications side by side. The carbon filter makes a huge difference to the airflow velocity at the face doesn’t it. The airflow on your vented S-D is almost twice as high!
          • barrybarfly
            • Nov 2023
            • 9
            #20
            I'm hoping members can see my posts which say awaiting moderation for visitors? I've been feeling rude for not replying to everyone but am not sure you can see my replies! Lol
            All things considered I think I'll definitely go for one of their recirculatory units (size being the only factor to consider) as I think it is the best solution for my given situation. This decision has been massively influenced not only by this thread but also threads on this site/forum I visited "as a guest" prior to joining. So for this I truly thank everyone for their knowledge.
            I would like to be able to offer opinions on other threads but I don't seem to have posting privileges in most sections of the forum! Anyone know if/when that will change?
            Thanks again!
            • Gern
              • 9212
              #21
              My extractor is not vented outside and faces a white tile wall. I hung a piece of card over the outlet just in case anything gets through and that has a faint circle of colour after about 5 years use. Nothing on the wall though. I do only spray acrylics so I have fewer issues with fumes.
                • 18892
                Thanks again!
                Hi Barry. You will get full access privileges if you become a supporter. At ten quid a year it is exceptionally good value :thumb2:
                • barrybarfly
                  • Nov 2023
                  • 9
                  #23
                  Done
                  • Gern
                    • 9212
                    #24
                    Done
                    You won't regret it - and it may turn out to be the best tenner you've ever spent!
                    PS Welcome aboard.
