What's on the Bench 2024
AND you be just mentioned why.
Too much choice would probably end up with me never completing anything.
For me, one or two is better. :thumb2:Comment
I just sprayed the loan-Jagdtigers:
[ATTACH]509181[/ATTACH]
Both Tamiya XF-88 Dark Yellow 2 all over, though one of the two will be camouflaged later.Comment
Last of the little blokes for a while. Oathmark 28mm Orc archers by North Star. D-Day group build beckons…..
[ATTACH=CONFIG]n1224565[/ATTACH]
I’ll post more pictures on the finished figures forum. https://www.scale-models.co.uk/threa...th-star.43432/
Look there if you want to see more of them. Any questions, just ask.Comment
A mate of mine asked me to recreate something like this:
[ATTACH=CONFIG]n1224618[/ATTACH]
He gave me these donor vehicles:
[ATTACH=CONFIG]n1224619[/ATTACH]
First job was to add the extra wheels:
[ATTACH=CONFIG]n1224620[/ATTACH]
Then I built the basic structure:
[ATTACH=CONFIG]n1224621[/ATTACH]
A bit of trimming here & there once it's all dry and I'll be ready to add some detail.Comment
I’ve been doing some more spraying on the Jagdtigers I have in my care. First the Porsche one, on which I’ve added highlights with a sand colour:
[ATTACH]509296[/ATTACH]
And the other one, which is now in camouflage plus highlights:
[ATTACH]509297[/ATTACH][ATTACH]509298[/ATTACH]Comment
Just a quick build while I’m waiting for the GP to start…..
Took about three sessions. Lovely little kit, and, not knowing much about the subject I’m not overly worried about accuracy. There is another one in the pack that I’ll work through before paint.
Should bolster my “elite“ 21st panzer division German gaming army…..apparently it had over thirty of these on its books.
May go for very worn panzer grey, which this “might” be….
Allows me to use it for earlier periods if I so desire as well.Comment
I scribed the lines using this set, which has different width blades:
To keep the lines straight I follow along some tape. Many types can be used but I've found this specific Dspiae tape to be better than anything else I've tried. It also has 1mm markings along it's length to help with keeping things equal or square and has a great adhesive that sticks well but can be removed & reused.
