What's on the Bench 2024
  • Andy the Sheep
    • Apr 2019
    • 1864
    • Andrea
    • North Eastern Italy
    #346
    Weathering will be a long process. Click image for larger version
ID:	1239836 First step done.
    • Andy T
      • Apr 2021
      • 3239
      #347
      More progress on this base. I cut down some long woodscrews and inserted the smooth end into holes drilled the depth of the MDF
      Then I glued the container at an angle, protecting the base so that it and the screws could be removed from the wood later. I used 5 minute epoxy, but even after 3 hours it was still soft and couldn't even support it's own limited weight. After a bit of heat it stiffened up enough for me to remove the assembly and reinforce it with more epoxy
      I'll keep adding more epoxy, but because it flows so much I can only add a bit at a time or it would be all over the place.
        Jim R commented
        Editing a comment
        Strange about the curing time. 5 mins epoxy is usually solid within half an hour. Does it have a use by date?
      • Andy T
        Andy T commented
        Editing a comment
        Not one I can see Jim. I bought it well over a year ago and it's endured the temperature extremes in my shed, so maybe that's a factor.
      • 18906
      Nice start on this Andy, Iโ€™m sure it will turn out as well as your other buildsโ€ฆ.
      Iโ€™ve been using epoxy on and off for over forty years now, and if you are interested, here are my thoughts on thisโ€ฆ..
      Epoxy can be weird stuff, especially the short acting five minute sort. It seems to be extremely reliant on exact proportion and a perfect mix between adhesive and hardener to set like itโ€™s supposed to. It will completely dry with time (usually about 24 hours) though, and just get harder as it ages. I think the chemical reaction takes a while to propagate through the material if the mix is even a little uneven, making the five minute epoxy react more like the 24 hour variety. I think what may happen is that the well mixed parts go off quickly, and the less well mixed parts have to wait for the catalyst in the hardener to permeate through the set areas before the reaction is complete. Warming it will speed the reaction up, but will make the epoxy more fluid to start with. Personally I use the ten minute variety if I can get it because you get slightly more working time and a more reliable set.
      The most reliable make Iโ€™ve found is Devcon. Never found a problem with the components ageing but I always use the stuff in two tubes and keep in at room temperature in the dark. Araldite used to develop a crust on the adhesive with age, so wasnโ€™t so good for long term storage between uses. Not used Gorilla glue so canโ€™t say how that alters over time, but I would certainly keep those clear tubes in the dark. Itโ€™s not something I use much these days, but Iโ€™ve probably only bought half a dozen packs in my modelling โ€œlifetimeโ€โ€ฆ
      • Steven000
        Steven000 commented
        Editing a comment
        Thanks for the info, I only use small bits of epoxy and after a while the tubes go bad, always 1 side that stays good/liquid and 1 side that gets very thick which makes it very hard to squish out...
      • Andy T
        Andy T commented
        Editing a comment
        Thanks Tim. I use a fair few 2 part adhesives and sealers in the day job so I'm usually pretty good at ensuring even quantities and thorough mixing, but something sure went awry with this.
        As I've just said to Jim above, it could be how poorly it was stored. I'll pay more attention to that in the future.
        Thankfully it's gone rock solid now, so all's good in the end.
    • Andy T
      • Apr 2021
      • 3239
      #349
      Cheating, but getting an idea of the main layout.
      I'm trying something different with the containers too. By sanding the black primer from the edges I'm hoping it will kind of pre-highlight for me
      • Steven000
        Steven000 commented
        Editing a comment
        Looks brilliant already Andy ?
    • scottie3158
      • 14201
      • Holbeach
      #350
      Great idea and brilliantly executed.
      • Richard48
        • 1896
        • Richard
        • Clacton on Sea
        #351
        Wow now thats inovative.Impressive
        • Andy T
          • Apr 2021
          • 3239
          #352
          Thanks guys.
          I've still got the tricky part to fully work out, but I'm waiting on a delivery of brass strip (cheers Paul for the details), before I can go much further.
          Thankfully the belly of the model is a separate piece and fits wonderfully, so I can crack on with the rest of it and join it up later.
          • Andy the Sheep
            • Apr 2019
            • 1864
            • Andrea
            #353
            I don't want to exaggerate; weathering finished. Next steps: towing cables (with flashes to be removed) an transparencies masking removal.
ID:	1240697 Click image for larger version
ID:	1240698 Click image for larger version
            • Andy T
              Andy T commented
              Editing a comment
              That's looking the business!
          • Richard48
            • 1896
            • Richard
            • Clacton on Sea
            #354
            Nicely done.Looks excellent.
            • Andy T
              • Apr 2021
              • 3239
              #355
              Following the way I believe they were painted in real life, I gave the Chinook a very quick & dirty camouflage:
              The after a protective coat of clear I sprayed the desert pink, adding some variation with bits of US desert sand and Middle Stone. I've gradually started abrading the pink away, as if sand blasted by the rotor downwash etc, to reveal some of the camo underneath. The picture doesn't show it well and it still needs more work, but it's getting to where I want it to be.
              • Andy the Sheep
                • Apr 2019
                • 1864
                • Andrea
                #356
                M1 is going from the bench to the shelf waiting for its final destination at my late friend's son home.
                Still pondering about the aerials, which should be there but in my models they seldom last more than 15 minutes...
ID:	1241093 Click image for larger version
ID:	1241094 Click image for larger version
                  Jim R commented
                  Editing a comment
                  That is excellent. Great paint job and love the stowage.
                • Tworrs
                  Tworrs commented
                  Editing a comment
                  Stunning work!!
                • Andy T
                  Andy T commented
                  Editing a comment
                  Very, very nice Andrea!
              • scottie3158
                • 14201
                • Holbeach
                #357
                That has turned out great.
                • Richard48
                  • 1896
                  • Richard
                  • Clacton on Sea
                  #358
                  Super doopah Andrea.Looks mighty fine fella.
                  • Airborne01
                    • Mar 2021
                    • 3976
                    • Steve
                    • Essex
                    #359
                    Very, very nice indeed!
                    • minitnkr
                      Charter Rabble member
                      • 7538
                      • Dayton, OH USA
                      #360
                      Very well done.
